Old 05-30-2013, 07:54   #1 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 896
Arrow nokia 101 blinking on nokia logo
hi to all
i have nokia 101
its problem is i on the set its only blinking on nokia
any brother have its solution plz post here
advance thanks
Old 05-30-2013, 08:11   #2 (permalink)
gsmretorque's Avatar
Member: 1902151
Thanks Meter: 60
you need to flash bro...
Old 05-30-2013, 08:41   #3 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 296
yes , i agree with you, he need to flash.
Old 05-30-2013, 09:41   #4 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 155
Originally Posted by saqi160 View Post
hi to all
i have nokia 101
advance thanks
You may check the display tracks for any rusts or liquid presence and clean it up if any is found. If this does not solve the problem, flash it and it is hoped it will be okay.
Old 05-30-2013, 13:14   #5 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 896
thanks for replay brothers
i tri to flash it .flash ok but same problem
i check the self test its show lcd ok
Old 06-01-2013, 13:48   #6 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 896
i remove its sim and mmc ic but same problem
Old 08-24-2013, 12:07   #7 (permalink)
Member: 583250
Brother this is losing in cpu you re ball with care, 100 percent solution
Old 07-04-2014, 11:30   #8 (permalink)
Member: 1676233
Sonork: 100.1648996
Thanks Meter: 3
i nokia101 flashing but same problem blinking
after heat cpu phone ok
Old 12-10-2014, 06:22   #9 (permalink)
Member: 833456
Thanks Meter: 4
Change boot ic between sim and mmc soket...100% tested by me
Old 12-10-2014, 07:56   #10 (permalink)
AMEERGUL's Avatar
Member: 669947
Sonork: 100.1614053
Thanks Meter: 156
dear what is fault in your sate only show logo then off or show logo but off in light
Old 12-14-2014, 12:49   #11 (permalink)
Member: 2158787
Dears I have flshed the phone twice but problem remaining the same, sold light ic and power ic, Inshalllah the problem will be solved. i did it with solding light ic and power ic, its working 100% now.
NY MOBILE ZONE & LAB
NASIR ALI
ISLAMABAD PAKISTAN
Old 12-14-2014, 12:59   #12 (permalink)
.....::::GsmAdeel:::::.....'s Avatar
Member: 767472
Sonork: 100.1609877
Thanks Meter: 582
no solution CPU damege..................
Old 12-15-2014, 07:48   #13 (permalink)
Crazy Poster
Member: 1135810
Sonork: fz
Thanks Meter: 4
yes it must be full flash, using latest firmware....!!!!!!!!
Old 01-29-2015, 06:29   #14 (permalink)
Registered User
Member: 1437921
Sonork: 100.1668345
Thanks Meter: 13
Thumbs up i remove its sim and mmc ic but same problem
Old 04-11-2015, 18:07   #15 (permalink)
Member: 2090485
Sonork: 100.1650866
nokia101 blinking on logo solved by applying some heat on boot ic between sim&memory card jacket.
The Following User Says Thank You to ishtiaq43 For This Useful Post:
Page generated in 0.33997 seconds with 7 queries
