Nokia 101 flashing ok but set is dead 100% working solution.. states of the phone is dead ... flashing with atf , flashing is ok but one error is show (lcd test failed ) http://i46.tinypic.com/1626zh4.jpg VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.200 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: BFB7 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 2B05 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.20mh PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x0061813E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5341504 bytes Data Checksum: 47D8 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai07.20mh_nlt CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00F49FFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 958464 bytes Data Checksum: BB37 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:32 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 07.20 30-03-12 RM-769 (c) Nokia IMEI: 353654055460122 Product Serial Number: 3D65DAFBI Product Code : 059J2D0 Module Code : 0204874 Basic Production Code: 059P5G1 PPM SW Version : V 07.20 30-03-12 RM-769 (c) Nokia MH ADSP Version : p+V 07.20\n30-03-12\nRM-769\n(c) NMP\nmh_nlt MCU SW Version : V 07.20 30-03-12 RM-769 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : UNKWN: IDs: 00:00:00 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : FAILED Phone Cannot Enter Normal Mode if LCD is Damaged or LCD is not Properly Connected to the Main PCB FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK apply this jumber.. 100% working..... http://i46.tinypic.com/2vnfac2.jpg http://i47.tinypic.com/kcnoqw.jpg phone is on condeshion..... http://i50.tinypic.com/34g3dhw.jpg |
br old solution ...... any new solution thxxxx......... |
1616, 5030 ,1662 etc..... pcb are different to 100 ,101 because its new solution...... |
My pictures will not show me what is the problem? |
yes its old solution but i am asking to read this post ... this post nothing to use fore you... you can note read it many other people like this post i am vary happy to this .. because (1616, 5030 ,1662 etc..... pcb are different to 100 ,101) i am testing 2 mobile then post it ....... any post you can read on time you will note use unknown camants are post it ok............ |
i am search ur all comments and u say "this solutions is old". i know u have sme experience bt u dont know how to respect people or their work. lol i know u r a sadist or jealous .bcoz if u know this is an old solutions then shut ur *****.suppose theire are so many peoples have no idea abt it.ok.if u think ur good then keep ur ***** silent ok.if u r a human just respect smeone work.you idiot going to continue this (comment something like this) then people not post their solutions to this forum ok u idiot.if u r a jenious then support people ok u dam dash |
thanks 1616, 5030 ,1662 etc..... pcb are different to 100 ,101 because its new solution...... |
very old solution.............................. |
bro which pins are you applied the jumper do you have a clear shot thanks |
Right to left 8th pin... |
nokia 101 dead in battery & ok in software first remove display from pcb. then check display connections if connections are missing please use jumber technique . if connections are ok, then change display. |
Nokia 101 flashing ok but set is dead........plz other solution......... solution not working... Nokia 101 flashing ok but set is dead. Phone Type: RM-769 SW version: V 07.70 18-10-12 RM-769 (c) Nokia ID Test name Startup Result 42 RADIO Y passed 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y !failed ! 80 KEY Y passed 81 PA Y passed 82 ADC1 Y passed 83 RTC_32KHZ Y passed 84 GPIO_LIGHT Y passed 85 HOOK_KEY Y passed 86 ACCESSORY Y passed 87 SIM_IF Y passed 88 SIM_INSERTED Y !no signal 90 FLASHCHK Y passed 94 SD_POWER Y !no signal 92 SIM2_IF Y passed 93 SIM2_INSERTED Y !no signal 91 SECURITY Y passed |
First check track is missing or not with multimeter. If track ok you have to replace lcd then. |
