Old 11-15-2012, 04:59   #1 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 233
Nokia 101 flashing ok but set is dead 100% working solution..
states of the phone is dead ...
flashing with atf ,
flashing is ok but one error is show (lcd test failed )
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.200
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: F5BE
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: BFB7
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: 2B05
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.20mh
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00100000~0x0061813E
Start Erasing...
Block Erase Done...
Data Size: 5341504 bytes
Data Checksum: 47D8
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai07.20mh_nlt
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00E60000~0x00F49FFE
Start Erasing...
Block Erase Done...
Data Size: 958464 bytes
Data Checksum: BB37
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:04:32
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 07.20 30-03-12 RM-769 (c) Nokia
IMEI: 353654055460122
Product Serial Number: 3D65DAFBI
Product Code : 059J2D0
Module Code : 0204874
Basic Production Code: 059P5G1
PPM SW Version : V 07.20 30-03-12 RM-769 (c) Nokia MH
ADSP Version : p+V 07.20\n30-03-12\nRM-769\n(c) NMP\nmh_nlt
MCU SW Version : V 07.20 30-03-12 RM-769 (c) Nokia
HW Version : 3000
UEM Version : 1328
UPP Version : 8850
LCD Version : UNKWN: IDs: 00:00:00
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : FAILED
Phone Cannot Enter Normal Mode if LCD
is Damaged or LCD is not Properly
Connected to the Main PCB
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
apply this jumber.. 100% working.....
phone is on condeshion.....
The Following 10 Users Say Thank You to anujc143 For This Useful Post:
Old 11-15-2012, 06:57   #2 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 733
br old solution ...... any new solution thxxxx.........
The Following User Says Thank You to biniesh_08 For This Useful Post:
Old 11-17-2012, 05:04   #3 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 233
1616, 5030 ,1662 etc..... pcb are different to 100 ,101 because its new solution......
Old 12-03-2012, 12:15   #4 (permalink)
Member: 1610241
Sonork: gsm_kermanshah
My pictures will not show me what is the problem?
Old 12-03-2012, 17:54   #5 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 233
Originally Posted by kathirmobiles View Post
bro very very ooooooooooooooooooooooold
yes its old solution but i am asking to read this post ...
this post nothing to use fore you... you can note read it
many other people like this post i am vary happy to this ..
because (1616, 5030 ,1662 etc..... pcb are different to 100 ,101)
i am testing 2 mobile then post it .......
any post you can read on time you will note use unknown camants are post it ok............
The Following 2 Users Say Thank You to anujc143 For This Useful Post:
Old 12-04-2012, 16:27   #6 (permalink)
rahulgsm7's Avatar
Member: 1810350
Sonork: 8888888
Thanks Meter: 9
i am search ur all comments and u say "this solutions is old". i know u have sme experience bt u dont know how to respect people or their work.
lol i know u r a sadist or jealous
.bcoz if u know this is an old solutions then shut ur *****.suppose theire are so many peoples have no idea abt it.ok.if u think ur good then keep ur ***** silent ok.if u r a human just respect smeone work.you idiot going to continue this (comment something like this) then people not post their
solutions to this forum ok u idiot.if u r a jenious then support people ok u dam dash
Old 06-17-2013, 12:27   #7 (permalink)
active_care's Avatar
Member: 1762926
Sonork: 1619564
Thanks Meter: 82
thanks 1616, 5030 ,1662 etc..... pcb are different to 100 ,101 because its new solution......
Old 06-17-2013, 15:36   #8 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,403
very old solution..............................
Old 06-17-2013, 15:46   #9 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 212
bro which pins are you applied the jumper do you have a clear shot thanks
Old 06-17-2013, 16:03   #10 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 536
Right to left 8th pin...
Old 06-18-2013, 16:46   #11 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 233
Old 07-04-2013, 13:54   #12 (permalink)
Member: 1717007
Sonork: Mystic ntiffam
nokia 101 dead in battery & ok in software
first remove display from pcb. then check display connections
if connections are missing please use jumber technique .
if connections are ok, then change display.
Old 07-26-2013, 13:25   #13 (permalink)
sweetsonu984's Avatar
Member: 1660122
Sonork: 100.1673803
Thanks Meter: 71
Nokia 101 flashing ok but set is dead........plz other solution.........
solution not working...
Phone Type: RM-769
SW version: V 07.70 18-10-12 RM-769 (c) Nokia
ID Test name Startup Result
42 RADIO Y passed
39 WARRANTY Y passed
33 SIM_LOCK Y passed
10 PPM_VALIDITY Y passed
43 LCD Y !failed !
80 KEY Y passed
81 PA Y passed
82 ADC1 Y passed
83 RTC_32KHZ Y passed
84 GPIO_LIGHT Y passed
85 HOOK_KEY Y passed
86 ACCESSORY Y passed
87 SIM_IF Y passed
88 SIM_INSERTED Y !no signal
90 FLASHCHK Y passed
94 SD_POWER Y !no signal
92 SIM2_IF Y passed
93 SIM2_INSERTED Y !no signal
91 SECURITY Y passed
Old 09-04-2013, 17:34   #14 (permalink)
Member: 2010588
Old 09-05-2013, 04:54   #15 (permalink)
Member: 982335
Thanks Meter: 189
First check track is missing or not with multimeter. If track ok you have to replace lcd then.
Page generated in 0.38147 seconds with 7 queries
