Old 10-19-2012, 04:44   #1 (permalink)
Member: 1467522
Sonork: 100.1596014
Thanks Meter: 30
Arrow Nokia 110 Lcd and Keypad Lights Solution by speed_tech14
Problem
- LCD and Keypad Lights
Action Taken
- Replace Coil and transistor no luck
Solution
- Jumper pin no. 2 to coil
Images
The Following 4 Users Say Thank You to speedXtech14 For This Useful Post:
Old 12-09-2012, 16:37   #2 (permalink)
pintu.pattnaik1's Avatar
Member: 1351981
Sonork: 100.1640597
Thanks Meter: 46
not working................................
Old 03-11-2013, 08:57   #3 (permalink)
tiju kkm's Avatar
Member: 699986
Sonork: TIJU
Thanks Meter: 392
Nokia 110 light solution
Old 05-04-2013, 09:11   #4 (permalink)
Member: 803835
Thumbs up 110 lcd light solution
check the track, and make the track safely
The Following User Says Thank You to rajesh_kuruvath For This Useful Post:
Old 05-04-2013, 10:33   #5 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 297
Problem
Action Taken
Solution
Images
how can it work becose you show direct supply to display connecto from battery conecctor. it is batery supply.no false solution.
The Following 2 Users Say Thank You to mahzra azra For This Useful Post:
Old 06-23-2013, 09:50   #6 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Need keypad solution nokia 110..
Old 08-02-2013, 10:30   #7 (permalink)
_..::MuSa::.._'s Avatar
Member: 1986151
Thanks Meter: 368
Old 08-03-2013, 15:33   #8 (permalink)
Member: 695084
Thanks Meter: 21
its working 100%after Replace Coil and transistor make this jump
Old 08-03-2013, 19:39   #9 (permalink)
Member: 1722956
Thanks Meter: 297
Problem
Action Taken
Solution
Images
wrong solution . How can you give directs supply from battery connector bacose coil takes supply from battery connector.it is all waste.
If you wants to make Nokia 110,112,114 display light follow it
1- remove transistor and diode.
2- transistor have 3 legs.1aheadand 2 legs behind. One leg become ground and second supply of behind legs.take a jumper from supply leg of transistor and joint it on display pin no-2.
3- make ground display pin no-3.
chek it 1000000%display light will be come.
4- if you want to make keypad light too,apply same trick for keypad light.
Note-- no need any transistor or diode and if you want to remove coil too you may remove.
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 08-04-2013, 13:43   #10 (permalink)
Member: 1884950
Sonork: 100.1647459
Thanks Meter: 2
i think lcd light not off when phone stanby
The Following User Says Thank You to vanminhdt For This Useful Post:
Old 09-10-2013, 05:49   #11 (permalink)
cellton512's Avatar
Member: 1049912
Sonork: cellmast
Thanks Meter: 98
Nokia 110 Lcd and Keypad No Lights...
[IMG]http://3.bp.********.com/-Kn77TsOz_X8/UNqJ4KwuCvI/AAAAAAAAWyw/CGps6X8CCoY/s400/nokia%2B110%2Blight%2Bsoultion%2B.jpg[/IMG]
The Following 3 Users Say Thank You to cellton512 For This Useful Post:
Old 09-10-2013, 05:59   #12 (permalink)
cellton512's Avatar
Member: 1049912
Sonork: cellmast
Thanks Meter: 98
[IMG]http://1.bp.********.com/-eBrjzbryFdo/UfN_Ya38U7I/AAAAAAAABIA/gqhS1uCG_oo/s640/Nokia+110++lcd+light+jumper.jpg[/IMG]
The Following 4 Users Say Thank You to cellton512 For This Useful Post:
Old 09-10-2013, 06:05   #13 (permalink)
cellton512's Avatar
Member: 1049912
Sonork: cellmast
Thanks Meter: 98
The Following User Says Thank You to cellton512 For This Useful Post:
Old 09-10-2013, 06:08   #14 (permalink)
cellton512's Avatar
Member: 1049912
Sonork: cellmast
Thanks Meter: 98
[IMG]http://3.bp.********.com/-siPhhnWqv7k/UQ-3ZXudH2I/AAAAAAAAAkg/au5U1IrL3dw/s1600/nokia+110+lcd+light+jumper+sulution.JPG[/IMG]
The Following 2 Users Say Thank You to cellton512 For This Useful Post:
Old 10-28-2013, 21:15   #15 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 43
Hi...
For all about say WITHOUT TRANZISTOR solution !!!
Please read here...
One copy display..or original display need 5.6-5.9 Volts for good light..
The display led is in series vith board led.....
In schematicd...Vled- Vbat=Vdisp+Vboard=5.7V+3V=aprox 9V...
VLed= aprox..13V
How can..without tranzistor(inverter)..with 3.6V on Vbat....power the 5.7V led?
Is simple electronics here...look on schematics....
Only solution is replace transistor from inverter( ok...repair inverter)..or change display led with one at 3V and put in paralel with board led..
TNX...
P.S. For all who want without transistor solution and all who put smooth picture on forum...
The Following User Says Thank You to DomnulV For This Useful Post:
Page generated in 0.62098 seconds with 8 queries
