Old 02-10-2007, 10:19   #1 (permalink)
Member: 283474
Thanks Meter: 41
nokia 1100 and 1600 backlite is not working
After soaking d pcb of 1100 and 1600 for some time, i dried it and d backlite refused to show, i think is d lite ic, can somebodi post me d real jumper that works , thanks
Old 02-10-2007, 10:59   #2 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
try this one...
br
Old 02-10-2007, 14:55   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,324
you can't make jumper on light ic
you have only two choise either change light ic with new one or put a ltyn as above of gsm blue's picture
good luck
Old 02-23-2007, 20:35   #4 (permalink)
Member: 283474
Thanks Meter: 41
if i remove d glass-like ic, won't it affect d functioning of other components or d ic's work is limited to d back light, more infor. about d ic is needed pls. Thanks a lot.
Old 02-24-2007, 00:55   #5 (permalink)
Member: 197538
Thanks Meter: 97
LED ic is only for LED ... first check coil if ok than change LED IC or do jumpering using 5 legged driver ,, u will find them in samsung flex belts old ones ,,, u can also use LED ic from other compatible nokia phones ,,
Enjoy AK
lg kg 200 menu and cleare botun is not working plz help guljee786 LG Hardware Repair 10 03-12-2009 08:46
RebelSim and G1 (htc) is not working realdeepdark Rebel SIM Card 2 02-13-2009 15:07
hi i buy a new advance ufs and support area is not working unlock_solution AdvanceUFS 4 01-03-2008 18:22
1600 earpace and headphone is working but ringer is not working zargar322 Nokia Hardware & Hardware Repair 3 05-29-2007 23:35
6600 AND 6230I camera is not working, blue_moon22 Nokia Hardware & Hardware Repair 2 09-18-2006 14:04
Page generated in 0.28276 seconds with 9 queries
