nokia 1100,2300 good solution for not charging. since the day nokia 1100 and 2300 came out in the market there is no still good or perfect solution for not charging problem...i hope this thread will guide us..so to the masters and specialists now is your time..please help us.. |
i am very much disappointed with this problem............. daily i recive one or two mobiles in this fault........... plug in the cahrger and on the display not charging.......... i had tried every soloution available on the forum..... but not a single time i sucesed............... so according to me final soloution change the uem........ that's it |
WBR ! |
1100 ,2300 Quote:
I am agree, that it is uem fault and its solution is change the uem but any type of jumpering must be done so that this problem will be solved without changing the uem. I hope in future there will be a solution. |
Guys give us a diagrame of that UEM which you mean pls? |
also with me last solution is change uem..but the big question here is HAVE YOU TRIED IT????? i still want to see a good solution here.. |
have u tried this..... plug in the charger without turning on the fon... if u c a chrging cell or a light black square all u have to do is change sum components |
on your left side of the flash u ill see three components... two capiseter n one thermal.... change the thermal from other board n enjoy.... |
plzz post back..... there r many more ideas |
How about a picture please? |
1100 charging Quote:
if you are not interested to change UEM.............then at least try to change R100........ R200...... And fusable Resistor K many times above things work.............. WBR... |
yes i m also feel trouble solving "NOT CHARGING" in DCT4 & WD2 mobiles |
@ khalifa we tested that but no good result still not charging...... |
