Old 08-31-2004, 19:57   #1 (permalink)
Member: 46341
Thanks Meter: 15
Nokia 1100 insert sim card
Helo nok 1100 olwaus insret sim card whit sim in.
Phone acept sim onlu when i push the phone somehaw.
So some lines are broken, a chek smol cristal near sim is ok.
Old 08-31-2004, 20:06   #2 (permalink)
Member: 39601
Thanks Meter: 13
Just cleaning of all the connectors and the SIM card itself is enough.
Old 09-01-2004, 12:37   #3 (permalink)
Member: 46341
Thanks Meter: 15
Jes that is enough when sim and conectors are dirty. But this in not the case.
There is brocken lines on pcb, but can not do much because all bga is glued.
Old 09-01-2004, 19:13   #4 (permalink)
Member: 39601
Thanks Meter: 13
What makes U thinks that it is a brocken line , I think it could be the ESD filter ( R388 ), if there is no taruma or direct cause of dammage U know.
Lets start with the SIM reader pins , check continuety of each of them to C381,382,and 383,as at the picture.
If every thing is allright try to reflow or change R388. This problem will not be more than those points.
Old 09-02-2004, 09:06   #5 (permalink)
Member: 79210
Thanks Meter: 7
chek to battery or change batery
Old 09-03-2004, 12:31   #6 (permalink)
Member: 78298
Thanks Meter: 6
replant or change r386,R386 looks like glasses..near the sim card pin.
Old 09-14-2004, 16:28   #7 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
@ Kriza
As you have to press the phone to read SIM means dry solder or open pins. Use good flux and properly reheat the area near SIM pads and components related to it. things should be OK.
Good luck.....
regards.
Old 09-15-2004, 01:48   #8 (permalink)
Member: 71751
Thanks Meter: 3
I have the same problem I think I'll try it.
Old 09-16-2004, 08:36   #9 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
@ kriza
SIM voltages are coming from CCONT as VSIM. Resolder/Rehot CCONT. Pin # 3 and 5 of SIM pads will have have voltage peeks after powering ON the phone. Check it. If still have the problem. Replace CCONT. If still have the problem, SIM digital lines are coming from MAD and it can not be repaired.
Good luck....
regards.
3100,1100,2600 nokia type insert sim card problems uncle smallz Nokia Digital Core Technology 4 ( DCT-4 ) 4 12-16-2006 16:03
1100 insert sim card moorthy Nokia Hardware & Hardware Repair 5 01-17-2006 17:25
Nokia 1100 insert sim card hitibiti Nokia Hardware & Hardware Repair 15 09-07-2005 18:43
needs help for nokia 1100 insert sim card pls help me some one Javajohn Nokia Hardware & Hardware Repair 2 07-09-2005 13:21
2300, 1100 insert sim card Help me Sticky ! amitks_in Nokia Hardware & Hardware Repair 12 04-21-2005 23:10
Page generated in 0.32507 seconds with 9 queries
