Old 01-01-2005, 19:00   #1 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
Nokia 1100 insert sim card
i have 5 nokia 1100 say insert Sim card !! ( imei is good not damajed )
any one know solution for this problem
i need service manuel mybe i can find solution
[email protected]
Thx
Old 01-01-2005, 19:10   #2 (permalink)
::.::SOUFIZ GSM::.::'s Avatar
Member: 59209
Thanks Meter: 19
here is the manner to repair
1- change battery it can solve the pb
2- with the multimter check the link betweenthe pin1.2.3. and there resistors inthe left down part of the sin connector is one link is down it can cause this pb
3-if the pb persist call me i'll give an other solution ican't wrote bit now because it's to deffecult to explain using english lang
21048657
Old 01-01-2005, 22:24   #3 (permalink)
yassinov®'s Avatar
Member: 51694
Thanks Meter: 5
Can be easy , can be hard !! look at battery ref if (BCL4 or BCL5) !!
use Bcl4 ! if not this can be a hard fault !
Old 01-02-2005, 16:02   #4 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
thx for all problem resolved
Old 01-13-2005, 15:52   #5 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,364
check the middle contact of your battery to battery terminal of your unit.
Old 06-14-2005, 09:37   #6 (permalink)
Registered User
snipergsm's Avatar
Member: 68983
Thanks Meter: 55
remove this (c 203) 100% work
Old 06-14-2005, 18:31   #7 (permalink)
.:Morpheus:.'s Avatar
Member: 47774
Thanks Meter: 185
Yes solution work fine tested by me also just remove c 203 hitibiti
Sniper no more Solution for u
( joke )
Old 06-14-2005, 18:45   #8 (permalink)
Member: 90058
Thanks Meter: 97
very nice work man thanking you
Old 06-14-2005, 22:33   #9 (permalink)
Member: 100195
Thanks Meter: 75
hi all
straight solut1on thx @snipergsm
sim reader flot 3. VSIM link
Old 06-14-2005, 23:52   #10 (permalink)
ANoNYMoUS_1's Avatar
Member: 153299
Thanks Meter: 59
thanks guys, very good solution..!
Old 08-05-2005, 16:26   #11 (permalink)
bhgsmservis's Avatar
Member: 45427
Thanks Meter: 141
Thanks,
This realy work.
Regards.
Old 08-05-2005, 16:40   #12 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
just change the battery man that the simple and straight solution
br
bitihel
Old 08-27-2005, 09:01   #13 (permalink)
Member: 110870
Red face 1100 problem
problem was Insert sim, I removed C203, now set is dead. Please help experts
Old 08-27-2005, 10:08   #14 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
[email protected]
Thx
Remove R388 and make jumpers, thats all!
Old 09-07-2005, 17:40   #15 (permalink)
cellcity's Avatar
Member: 58052
Thanks Meter: 21
most of insert sim on dct4 models is to make a jumper on r388 i repair already a couple and works 100%
3100,1100,2600 nokia type insert sim card problems uncle smallz Nokia Digital Core Technology 4 ( DCT-4 ) 4 12-16-2006 16:03
1100 insert sim card moorthy Nokia Hardware & Hardware Repair 5 01-17-2006 17:25
needs help for nokia 1100 insert sim card pls help me some one Javajohn Nokia Hardware & Hardware Repair 2 07-09-2005 12:21
2300, 1100 insert sim card Help me Sticky ! amitks_in Nokia Hardware & Hardware Repair 12 04-21-2005 22:10
Nokia 1100 insert sim card KRIZA Nokia Hardware & Hardware Repair 8 09-16-2004 07:36
Page generated in 0.26301 seconds with 10 queries
