.: Nokia 1100 No Network Found :. Nokia 1100 In No Network . Search Manualy Show "No Net Found" All Ready Make Jumper On Antina Siwich & Change PF But Problem Is Still |
did u flash the phone..! |
bro, jumper is not perfect solution, so change antina switch and then post your result |
1100 Network I Try Your Sujection But Problem Is Still (Thanks For Sujection) |
hello,br antenna switch under, R.F I.C uppear(Z 601,Z602)Filters removed. And Then connect P.F's. |
try to write gud pm then set works fine |
1 Attachment(s) remove antina switch short these red points |
try to change filters. |
bro, is you tried to change anitana switch then change filter if not ok then reball RF ic post your result |
I Have Change Filter (Z601, Z602) But Problem Is Not Solved (Thanks For All Helper) "What I Do" |
try to reball RF ic................. |
IN MOST CASES WHEN YOU HAVE THE MESSAGE "NO NETWORK FOUND" AFTER MANUAL SEARCHING, THE POWER AMPLIFIER IS THE SUSPECT. JUST CHANGE IN A NEW PA AND THE PHONE WILL WORK WELL. I HAVE DONE THIS TIMES WITHOUT NUMBER. |
Wat Time It Takes To Show U No Network Found If Its Less Than 7-8 Sec Means Its Antina Switch If It Show Just Searching After 1 Minute Or More Time Just 1st Try To Flash The Phone Write A Tested Network Pm If Still Same Replace Pf |
