Old 10-02-2006, 19:14   #1 (permalink)
.::Munazzam::.'s Avatar
Member: 251247
Sonork: 1001670304
Thanks Meter: 192
nokia 1100 UI defaults failed
hello all mates
i realy very upset i flashed nokia 1100 wich was in restart problem when set the time.. but when i flashed it it complete flashed but not accept UI defaults or when i use jaf the same status and set is not powering on. customer is to my neck . i used downgrade or latest flash files till 8.1 but no success.plz help me.
with big thanks.
Munazzam.
Old 10-02-2006, 19:34   #2 (permalink)
Cheater -Don't Deal with him-
..::hotlovercool4::..'s Avatar
Member: 240342
Sonork: 100.1576037
Thanks Meter: 852
Wink try erase and then flash
try erase and then flash cheek the cable ?
wink shafeeq
geo mobiles
Originally Posted by apna_mobile View Post
hello all mates
with big thanks.
Munazzam.
Old 10-03-2006, 08:05   #3 (permalink)
Bagscom's Avatar
Member: 319976
Thanks Meter: 14
do full erase flash and flash it with higher version after flashing if the local mode affair load pm files and unlock do not make ui defaults. do it in your fon manually do factory setting in your fon.
Old 10-06-2006, 18:45   #4 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
hello all mates
with big thanks.
Munazzam.
Are you sure you have flashed the phone with the same version that it was before.Because you were supporse to read information so you can know the firmware version.If not change tje flash file untill its compartable to your mobile phone.
7610 ui default failed smartcell Nokia Hardware & Hardware Repair 2 07-01-2006 21:23
1100 ui defaults failed??? sallu Nokia Digital Core Technology 4 ( DCT-4 ) 0 06-03-2006 05:47
6610 UI Defaults Failed johannlambros Nokia Digital Core Technology 4 ( DCT-4 ) 1 12-15-2005 03:23
6610 UI Defaults Failed johannlambros UFS2 + UFS3-Tornadoflasher 1 11-09-2005 21:55
6230 ui default failed benie UFS2 + UFS3-Tornadoflasher 0 02-24-2005 11:11
Page generated in 0.57311 seconds with 9 queries
