Old 02-17-2007, 15:34   #1 (permalink)
Member: 453189
Thanks Meter: 9
Thumbs up Nokia 1108 RH-18
Hi have nokia 1108 RH-18 haveing problem... when i swetchon mobile cant see anything on screen only can see white screen. pls help me what to do any jumper soluction or it ? pls help me
Last edited by hhhhhh111111; 02-17-2007 at 15:37. Reason: no responce for this post
Old 02-17-2007, 17:11   #2 (permalink)
Member: 350948
Thanks Meter: 32
Flash with latest version,it works.
Old 02-17-2007, 18:24   #3 (permalink)
Member: 249464
Thanks Meter: 4
if you can recieve call with it, then it is lcd problem,if not,it is software problem, flash it, it will be okay
Old 02-18-2007, 06:33   #4 (permalink)
sonuveene's Avatar
Member: 308760
Thanks Meter: 47
Thumbs up 1108
hi frnd,
first full erase flesh and again full flesh with 4.1 and write good pm.
Old 02-18-2007, 07:49   #5 (permalink)
Member: 445609
Thanks Meter: 27
try flshing it with an higher version
Old 02-18-2007, 13:48   #6 (permalink)
techseeker"ems"'s Avatar
Member: 343227
Thanks Meter: 22
boss try to check first. if it is in contact service state? phone can't make or recieve call. then flash it with a higher version of firmware... hope this helps!
Old 02-19-2007, 07:18   #7 (permalink)
Member: 453189
Thanks Meter: 9
still problem....
Friends when i try to flash i got this message
"1st Boot Err: Bad Resp UPP, 03 00 00 72
Process Failed, Repowering Mobile"
what to do pls tell me...
Old 02-19-2007, 07:19   #8 (permalink)
Member: 453189
Thanks Meter: 9
What to do?
Originally Posted by sonuveene View Post
hi frnd,
when i try to flesh i got this error message
what to do ?
Old 02-19-2007, 07:23   #9 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
what to do ?
Please check FBus Cable Mate.
Old 02-19-2007, 07:35   #10 (permalink)
Member: 453189
Thanks Meter: 9
Cable is ok...
this is the problem...
Languages in ppm: English,French,German,Italian
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\RH-18\rh18_05.620
Booting phone...
MCU ID: 0x0000
This MCU ID is not supported in chosen flash file...
Error booting phone...
now ??? tired yaar
Old 02-19-2007, 07:37   #11 (permalink)
Member: 453189
Thanks Meter: 9
Red face full info of my flesher screen...
here i give full info what i got when i try to flesh...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RH-18\rh18_05.620
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-18\rh18_05.62ae
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Failed! Aborting!
Booting phone...
MCU ID: 0x0000
Any idea ???
Old 02-19-2007, 08:12   #12 (permalink)
BraveNewWorld's Avatar
Member: 150193
Thanks Meter: 93
Cable problem. Can't you understand what other people post.
Old 02-22-2007, 17:45   #13 (permalink)
Member: 453189
Thanks Meter: 9
Thanks all Friends... Problem solve
Thanks All Friends For Help Me Its Working Now .... Flesh With New Version And Its Working It Was My Mistake That I Didnt Checke Version Ne Ways Thanks All Friends For Help Me And Post Help For Me ... Thanks Again
Old 02-22-2007, 17:58   #14 (permalink)
Member: 365744
Thanks Meter: 54
Arrow be careful next time
Be verycareful next time u may end up damameging a customers phone and u will fail to reverse it ,b4 N thing check the phone modale coz most of the look the same ,e.g 1100,1101,and so on
Old 03-02-2011, 15:32   #15 (permalink)
Member: 1486400
Sonork: tamilmurugan
dear sir i have nokia 1108 some problem for condact service u have solution for without flashin mobile flashing?
nokia 1108 RH-18 1800Mhz problem..!!! hhhhhh111111 Nokia Hardware & Hardware Repair 2 07-17-2009 19:06
Nokia 1108 RH-18 Blank screen problem hhhhhh111111 Nokia Hardware & Hardware Repair 3 02-27-2007 07:20
Nokia 1100a RH-18 chrisonic Nokia Digital Core Technology 4 ( DCT-4 ) 3 01-04-2005 15:55
Nokia 1100 RH-36 to Nokia 1100 RH-18 lugonza Nokia Digital Core Technology 4 ( DCT-4 ) 0 04-04-2004 03:27
Page generated in 0.42343 seconds with 9 queries
