nokia 1110 and 1600..... key pad and no led nokia 1110, there is no light when the coil removed, and i try to bridg the inerface of the coil and stil yet no light. please what is the solution? when the coil has been the removed. |
nokia 1110, there is no light when the glass ic beside of the coil removed, and i dont know how to connet the glass ic interface any body how know the reading of the panel it can send it to me, to my email address [email protected] OR [email protected] |
nokia 6060, menu key is not working what is the solution? |
nokia 1600, key pad 2,5,8,0 is not work what is the solution? |
No light will come when coil is removed.If coil is damaged then wind 7-8 turns of thin wire on that core and solder 2 ponts of wire to pcb were coil is soldered.for glass is there is a dot symbol on ic this symbol is toward '7' no. key.for 6060 and 1600 keys change keypad ic. |
replace with new light ic.....all fine...post result regards PUNEET14884 :) |
replace keypad driver ic..........all fine regards PUNEET14884 :) |
1 Attachment(s) Quote:
replace another coil don't bridg it that will work |
to solve the keypad problem for 1600 change the keypad ic it's located near the sim base |
thanks........................ |
1600 keypad 2,5,8,0 1 Attachment(s) Quote:
