Old 07-15-2007, 02:15   #1 (permalink)
Member: 165835
Thanks Meter: 3
nokia 1110 and 1600..... key pad and no led
nokia 1110, there is no light when the coil removed, and i try to bridg the inerface of the coil and stil yet no light. please what is the solution? when the coil has been the removed.
Old 07-15-2007, 02:24   #2 (permalink)
Member: 165835
Thanks Meter: 3
nokia 1110, there is no light when the glass ic beside of the coil removed, and i dont know how to connet the glass ic interface any body how know the reading of the panel it can send it to me, to my email address [email protected] OR [email protected]
Old 07-15-2007, 02:28   #3 (permalink)
Member: 165835
Thanks Meter: 3
nokia 6060, menu key is not working what is the solution?
Old 07-15-2007, 02:31   #4 (permalink)
Member: 165835
Thanks Meter: 3
nokia 1600, key pad 2,5,8,0 is not work what is the solution?
The Following User Says Thank You to allstarint2000 For This Useful Post:
Old 07-15-2007, 08:16   #5 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
No light will come when coil is removed.If coil is damaged then wind 7-8 turns of thin wire on that core and solder 2 ponts of wire to pcb were coil is soldered.for glass is there is a dot symbol on ic this symbol is toward '7' no. key.for 6060 and 1600 keys change keypad ic.
Old 07-15-2007, 08:20   #6 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Arrow
replace with new light ic.....all fine...post result
regards
PUNEET14884
Old 07-15-2007, 08:22   #7 (permalink)
Member: 399779
Thanks Meter: 125
Arrow
replace keypad driver ic..........all fine
regards
PUNEET14884
Old 07-15-2007, 14:58   #8 (permalink)
syl phone's Avatar
Member: 320823
Thanks Meter: 1,592
try this i think its can solv ur problem
The Following User Says Thank You to syl phone For This Useful Post:
Old 07-16-2007, 14:15   #9 (permalink)
oss001's Avatar
Member: 545608
Thanks Meter: 25
replace another coil don't bridg it that will work
The Following User Says Thank You to oss001 For This Useful Post:
Old 07-16-2007, 14:18   #10 (permalink)
oss001's Avatar
Member: 545608
Thanks Meter: 25
to solve the keypad problem for 1600 change the keypad ic it's located near the sim base
Old 07-27-2007, 06:55   #11 (permalink)
Vibin A's Avatar
Member: 413644
Thanks Meter: 10
first you chang the key pad ic, if not ok the problem will solve only by changing UPP
Old 04-19-2008, 16:46   #12 (permalink)
Member: 565755
Thanks Meter: 5
thanks........................
Old 04-19-2008, 17:10   #13 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Dude many times discuss this problem,
Use SEARCH button.
Simply see this thread.
Amol_Sm
Old 04-19-2008, 18:18   #14 (permalink)
Member: 641166
Thanks Meter: 331
1600 keypad 2,5,8,0
The Following 2 Users Say Thank You to galant2 For This Useful Post:
Old 04-19-2008, 23:04   #15 (permalink)
Vibin A's Avatar
Member: 413644
Thanks Meter: 10
change the key pad esd filter
NOKIA 1110/1112/1600 Battery low SolutionNOKIA 1110/1112/1600 Battery low Solution gsm junction Nokia Hardware & Hardware Repair 3 05-06-2013 13:02
need solution for k618i no light in key pad and shorted lilong_lee Sony Ericsson Hardware Repair 0 03-22-2010 06:10
w850 no light in key-pad and lcd HELP ME!!! zoni Sony Ericsson Hardware Repair 5 07-14-2009 04:30
nokia 5300 lcd n key pad no light (water damage) Kian9159 Nokia Hardware & Hardware Repair 0 08-11-2008 12:01
Nokia 1110 & 1600 Key Pad gbadega Nokia Hardware & Hardware Repair 7 06-13-2007 18:38
Page generated in 0.24468 seconds with 10 queries
