06-30-2008, 16:49 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Bhilwara(Rajasthan)India
Member: 643992 Status: Offline Sonork: 100.1625367 Thanks Meter: 180 | Nokia 1110-i insert sim all of you my problume is that in nokia 1110i Insert Sim. I will try remove Sim IC But No result. Then i make sim ic Jumper . But this is not Success. any body tell me what can i do for this problume . Thanks in Advance................ |
The Following 3 Users Say Thank You to jkniji For This Useful Post: |
06-30-2008, 17:21 | #2 (permalink) |
Freak Poster Join Date: Jun 2007 Location: pakistan Age: 40
Member: 522050 Status: Offline Thanks Meter: 62 | 1110i insert sim replace sim ic not jumper (use sim ic from any bord not new ) i have tasted |
The Following User Says Thank You to omer farooq bha For This Useful Post: |
06-30-2008, 19:51 | #4 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Midddle of heaven and hell. Age: 35
Member: 489876 Status: Offline Thanks Meter: 277 | Ok brother try this solution.It works fine.If works for u pls replay and hit thanks button. |
The Following 7 Users Say Thank You to eafta For This Useful Post: |
06-30-2008, 20:00 | #5 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | i agree eafta. But before you replace sim ic, please check all of that point, if one of point short or cut, replace or change ur power ic |
The Following User Says Thank You to AdickAsia For This Useful Post: |
07-11-2008, 12:01 | #9 (permalink) |
Junior Member Join Date: Apr 2008
Member: 740287 Status: Offline Thanks Meter: 7 | all of you my problume is that in nokia 1600 Insert Sim. I will try remove Sim IC But No result. Then i make sim ic Jumper . But this is not Success. any body tell me what can i do for this problume . Thanks in Advance................ |
The Following 2 Users Say Thank You to bablu007 For This Useful Post: |
07-11-2008, 13:17 | #10 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | For better don't do the jumper. Just change the sim IC. Did u change this one or U only try to jumper . . . ? Post result. |
The Following User Says Thank You to amol_sm For This Useful Post: |
07-16-2008, 07:19 | #11 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471777 Status: Offline Thanks Meter: 55 | hi, dud what z up? bey the by 1110i & 1600 is as it is so chick dis out. Hello, all of you my problume is that in nokia 1110i Insert Sim. I will try remove Sim IC But No result. Then i make sim ic Jumper . But this is not Success. any body tell me what can i do for this problume . Thanks in Advance................[/quote] |
The Following 5 Users Say Thank You to Raa_z For This Useful Post: |
07-17-2008, 08:56 | #12 (permalink) |
Junior Member Join Date: May 2008
Member: 770002 Status: Offline Sonork: 123 Thanks Meter: 6 | i repair many mobiles of insert sim by cheking BSI the centerl point of battry connecter this point somtime does not touch the battry and showing insert sim try and post result |
07-22-2008, 10:24 | #15 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Inside Boxes
Member: 228871 Status: Offline Thanks Meter: 43 | Quote:
Check the jumpers if OK then change the Battery if same then Change the Charging jack..... | |
1110 1600 insert sim ..''..(easy way)..''.. | imran zafar | Nokia Hardware & Hardware Repair | 9 | 12-18-2009 09:21 |
1110-1600 insert sim card solution | reaj | Nokia Hardware & Hardware Repair | 5 | 10-24-2009 06:14 |
1110 china insert sim plz help | asif_ae | Chinese Models & Cloned Phones | 9 | 08-31-2009 09:37 |
1110/1600 insert sim solution | sigma xi | Nokia Hardware & Hardware Repair | 5 | 11-16-2008 20:03 |
2310,1110 int insert sim when we make call after 1 minute | CHAPRAN | Nokia Hardware & Hardware Repair | 16 | 05-21-2008 20:07 |
