Old 11-25-2008, 08:31   #1 (permalink)
Member: 318781
Thanks Meter: 50
****-----Nokia 3110C New Restart Solution----*****
hello brother i know every body have this problem
i have solution that i have tested in 50 to above and always success
flash ur phone using JAF with 6.01
then format ur with mmc with the help of device "using file system format"
when open file system in jaf
there are two or three drives in there format all
now power on ur set
all ok but you have only one problem left
which is u dont have any pic and tunes in ur mobile
connect again ur set with jaf and write only cnt file and do factory reset
All ok 10000000000%%%%%%%%
You can also use UFS for this procedure
test and reply
and press thanx if u will success
The Following 8 Users Say Thank You to mutewitness_akp For This Useful Post:
Old 11-27-2008, 22:42   #2 (permalink)
nitin28's Avatar
Member: 309831
Sonork: 100.1601174
Thanks Meter: 14
great sir helpfull info
Old 11-28-2008, 11:23   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
old solution my friend already posted in this forum , but good for newbies
Old 11-28-2008, 12:08   #4 (permalink)
tiju kkm's Avatar
Member: 699986
Sonork: TIJU
Thanks Meter: 394
3110 restart problem i flash with 6.02 v problem solved 10000%
Old 11-28-2008, 14:19   #5 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
yes 6.01 & 6.02 both are working very well..........
Old 11-28-2008, 17:04   #6 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
No need to flash it brother....just restore factory settings without mmc and format mmc in computer.....10000000000000 times tested...Thanx...Try and reply
Old 11-28-2008, 17:32   #7 (permalink)
Member: 457250
Thanks Meter: 3
this is very old soulation
Old 11-28-2008, 17:39   #8 (permalink)
Member: 302843
Thanks Meter: 111
old solution already posted in forum..............
Old 11-28-2008, 17:57   #9 (permalink)
Member: 390195
Thanks Meter: 17
old but best for new comer i aprishat dear
Old 11-28-2008, 18:12   #10 (permalink)
TUR@N ALAM's Avatar
Member: 705213
Sonork: https://wa.link/aru52t
Thanks Meter: 2,735
  1. mobile format with jaf/ufs & ui setting
  2. mobile sim input. set reset factory setting
  3. mmc format with pc
  4. mmc input your set and 1 more formate mmc
  5. one more set fectory setting
  6. 100000000% solved your problem
The Following User Says Thank You to TUR@N ALAM For This Useful Post:
Old 11-28-2008, 19:09   #11 (permalink)
gsm-roddur's Avatar
Member: 426796
Thanks Meter: 60
also restart solve flash the phone RM-237_DP20_7.00__sw-07.01_3110c_2 version format the MMC card nothing ales
The Following User Says Thank You to gsm-roddur For This Useful Post:
Old 12-19-2008, 07:07   #12 (permalink)
Member: 392116
Thanks Meter: 18
3310c restart
after flash jaf says
DCT4/BB5 counter: 203
After flash processing...
Waiting for phone to boot...
how to solve this
Failed! Aborting!
Old 01-01-2009, 11:43   #13 (permalink)
Member: 477608
Thanks Meter: 6
Nice job , good work ,
Old 01-01-2009, 13:40   #14 (permalink)
broken_rules's Avatar
Member: 698819
Thanks Meter: 122
goodd work broo.. keeP ItUP
now power on ur set
test and reply
Reallyy GREAT WORK BROO>>> THNX KEEp pOSting
nokia 6500 s restart solution mohamedsahhar Nokia Hardware & Hardware Repair 20 07-03-2011 17:43
Help for nokia 3110c battery low solution mahesh123 Nokia Hardware & Hardware Repair 13 11-07-2010 22:55
nokia 3110c hands free solution greshanwg Nokia Hardware & Hardware Repair 0 03-10-2010 08:26
Nokia 3110C New Restart Solution mutewitness_akp Nokia Base Band 5 ( BB-5 ) 1 02-11-2009 18:35
nokia 3110c keeps restarting help!!!! fyfee1981 Nokia Hardware & Hardware Repair 2 07-10-2008 22:19
Page generated in 0.20060 seconds with 10 queries
