nokia 1110 no effect on charger pls. kindly help for nokia 1110 when charger is plug no effect. please what will i do to solve this problem?. |
Check Check The Fuse Coil And Glass Diode Near The Charging Connectorcheck .22 Ohm Resistor Over The Radio Ic Space. |
yes ....Check The Fuse Coil And Glass Diode Near The Charging Connectorcheck .22 Ohm Resistor Over The Radio Ic Space.... |
thanks sujan ....i will try it.............. |
pls. diagram needed to understand this illustration beter. |
ya, Check The Fuse Coil And Glass Diode Near The Charging Connector check .22 Ohm Resistor Over The Radio Ic Space.... |
please give me a diagram if u can... thanks |
