Old 06-05-2008, 22:05   #1 (permalink)
Member: 127428
Thanks Meter: 51
nokia 1110 no effect on charger
pls. kindly help for nokia 1110 when charger is plug no effect. please what will i do to solve this problem?.
The Following User Says Thank You to barthosyn For This Useful Post:
Old 06-06-2008, 02:56   #2 (permalink)
Member: 457470
Thanks Meter: 156
Check
Check The Fuse Coil And Glass Diode Near The Charging Connectorcheck .22 Ohm Resistor Over The Radio Ic Space.
Old 06-16-2008, 10:15   #3 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
yes ....Check The Fuse Coil And Glass Diode Near The Charging Connectorcheck .22 Ohm Resistor Over The Radio Ic Space....
Old 06-16-2008, 13:27   #4 (permalink)
Member: 718473
Thanks Meter: 8
thanks sujan ....i will try it..............
Old 10-31-2008, 20:22   #5 (permalink)
Member: 127428
Thanks Meter: 51
pls. diagram needed to understand this illustration beter.
Old 01-01-2009, 13:55   #6 (permalink)
Member: 469014
Thanks Meter: 39
ya, Check The Fuse Coil And Glass Diode Near The Charging Connector check .22 Ohm Resistor Over The Radio Ic Space....
Old 01-01-2009, 13:57   #7 (permalink)
Member: 469014
Thanks Meter: 39
please give me a diagram if u can... thanks
Old 01-01-2009, 14:08   #8 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 436
http://s486.photobucket.com/albums/r...DIOWAYES-1.jpg
se tis pic................
The Following 2 Users Say Thank You to RATHNAMOBILESS For This Useful Post:
nokia 1200 no effect on charging barthosyn Nokia Hardware & Hardware Repair 1 12-05-2009 02:05
nokia 1110 no effect on charger barthosyn Nokia Hardware & Hardware Repair 0 08-27-2008 10:47
nokia 1110i no effect for charger barthosyn Nokia Hardware & Hardware Repair 6 06-20-2008 21:57
Ust Pro 11 Problem. No Effect On Phone After Flashing. alhajikoroma UST Pro II 4 01-02-2008 23:53
nokia 1100 no effect on charging barthosyn Nokia Hardware & Hardware Repair 5 05-22-2007 10:13
Page generated in 0.30639 seconds with 8 queries
