Old 10-03-2006, 18:36   #1 (permalink)
Member: 299602
Thanks Meter: 8
Nokia 7650 powering up problem.
Hello,
I wonder if anyone can help with a little problem I have with a Nokia 7650.
When it is powered up it is 100% perfect everything works, but when you turn it off the fun begins, Nothing happens, press the on/off button and the set just lays there dead, no response from charging either. leave the phone for awhile and then it powers up and works fine!... possest?
ok, obvious things like battery, switch and flexi cable seem ok,
can anyone Help...please..........
Chris
Old 10-05-2006, 16:18   #2 (permalink)
pava's Avatar
Member: 80567
Thanks Meter: 53
99%is the flat cable
Old 10-05-2006, 17:34   #3 (permalink)
Member: 299602
Thanks Meter: 8
Just changed cable with a known good cabel, still the same. once the phone powers up it is fine no prpblems atall, guess I just will have to leave it turned on!
Thanks any way Chris
Old 10-08-2006, 02:34   #4 (permalink)
ea12345's Avatar
Member: 130345
Thanks Meter: 10
Yes its 100% cable problem
Old 10-08-2006, 06:12   #5 (permalink)
Member: 223959
Thanks Meter: 8
yes the problem is with flex cable once there was 7650 with but in that there was a network problem i tried everything to repair network but didnt found any success somebody told me to change the cable in this forum i changed it & the network was succesfully repaired i m sure in ur case also there is a problem of cable
Old 10-11-2006, 11:01   #6 (permalink)
Member: 223959
Thanks Meter: 8
had u tried the solution
Old 11-08-2006, 21:06   #7 (permalink)
badwily's Avatar
Member: 241933
Thanks Meter: 77
Originally Posted by hi_chris View Post
Hello,
Chris
Hi 2 all
I have the same problem with nokia 7650.... i have changed the flex cable to pad and no result........
anyone have more ideas
7650 power up sirharlequin WD2 & APE (Symbian Phones) 3 08-14-2003 18:14
T20e power up problem legija Sony Ericsson Hardware Repair 2 09-02-2002 21:34
Gd 92 power up problem GSM RAJ Panasonic 0 07-28-2002 12:55
flash power up problem kage Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-04-2002 17:51
Trium Mars K08 Power up Problem! valdeira Mitsubishi 1 10-07-2001 21:03
Page generated in 0.15975 seconds with 10 queries
