Old 06-26-2013, 08:48   #1 (permalink)
Member: 604209
Thanks Meter: 2
nokia 112 charging not supported (need help)
thanks
Old 06-27-2013, 20:24   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
first replace d charging fuse then check if still same then remove marked varistor .
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 09-27-2013, 04:00   #3 (permalink)
Member: 1746439
thanks for the reference ................................
Old 09-27-2013, 04:37   #4 (permalink)
ashishsingh's Avatar
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
http://forum.gsmhosting.com/vbb/f148...orted-1681657/
Old 12-11-2015, 12:48   #5 (permalink)
Member: 515940
Thanks Meter: 29
SARCAR SIR i try this ( first replace d charging fuse then check if still same then remove marked varistor) but same problem .......
Br//
Saini
Old 12-12-2015, 09:06   #6 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
only battery change Nokia battery bL-6 supported battery..
The Following User Says Thank You to linux_sh For This Useful Post:
Page generated in 0.15571 seconds with 9 queries
