11-25-2013, 06:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1727103 Status: Offline Sonork: [email protected] Thanks Meter: 13 | Nokia 114 after nokia logo white lcd strange problem.. |
11-25-2013, 06:56 | #2 (permalink) | |
Member: 1727103 Status: Offline Sonork: [email protected] Thanks Meter: 13 | Quote:
Here is flashing log Number of Image Files: 3 Processing Image File : rm827__03.47.mcusw Processing Image File : rm827__03.47.ppm_mh2 Processing Image File : rm827__03.47.image_mh2_059Q9J5 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12200C072A082820 Original Product Code: 059Q9H7 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355203055978721\3552030559787 21_110951.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355203055978721\3552030559787 21_CERTIFICATE_BFDC75D3.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355203055978721\3552030559787 21_PMM_PROT_33507296.bin Security Code: 12345 Data Sections : 04 Current File : rm827__03.47.mcusw Compile Name: rm827__03.47.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27266440 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 43E7 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A82 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 7E8E Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25952256 bytes Data Checksum: BC98 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm827__03.47.ppm_mh2 Compile Name: package_mh2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 3567936 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41BC0000~0x421BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 3564592 bytes Data Checksum: 7D31 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm827__03.47.image_mh2_059Q9J5 Compile Name: package_mh2_059Q9J5.image.fls Image Type : CONTENT Package Data Size : 17042704 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x421C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 17039360 bytes Data Checksum: 1942 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:08:00 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.47 31-05-13 RM-827 (c) Nokia IMEI Plain : 355203055978721 IMEI Spare : A355203055978720 IMEI SV : 33552030559787219F IMEI (2nd) : 355203055978739 IMEI Spare : A355203055978730 IMEI SV : 33552030559787319F Phone Model: K 114 Category : Entry Phone Phone Type : RM-827 ================================================ Extended Phone Information ================================================ Product Serial Number: 888AF3CBI Product Code : 059Q9H7 Module Code : 0205463 Basic Production Code: 059Q9D6 Long Production SN : 0 PPM SW Version : V 03.47 31-05-13 RM-827 (c) Nokia MH2 MCU SW Version : V 03.47 31-05-13 RM-827 (c) Nokia HW Version : 2200 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: mh2_059Q9J5 V 03.47 31-05-13 RM-827 (c) Nokia Bluetooth ID : B0:35:8D:65:91:E4 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS0000040C21AC67 DCC Ver: 004032 Status : OK ================================================== ==== Selected VPL File: RM827_059Q9J5_03.47_041.vpl ================================================== ==== Variant Details : RM-827 INDIA_MH2_CYAN_LATIN_IN_S Software Version : 03.47 Product Type : RM-827 Product Code : 059Q9J5 Variant Version : 041 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK | |
The Following User Says Thank You to yogacharya For This Useful Post: |
11-25-2013, 07:13 | #3 (permalink) | |
now showing st_lcd test failed ...... all track is ok | |
11-25-2013, 14:32 | #4 (permalink) |
Member: 1727103 Status: Offline Sonork: [email protected] Thanks Meter: 13 | hello .... anybody have idea about white lcd problem ? all track is ok and also tried remove resistance and put jumper but not working. |
