Old 11-15-2010, 13:09   #1 (permalink)
Member: 891893
Thanks Meter: 24
Arrow Nokia 1200 blank display
There is a nokia 1200 which is blank display problem. I have already changed Display,Flex but yet the same problem. I have already updated software. Incoming and outgoing call is ok but still blank display. I think this is due to open the display connecter track. If there is any other solution kindly provide that and the display connecter track jumper also.
Old 11-15-2010, 13:13   #2 (permalink)
Member: 1291352
Sonork: +919993264376
Thanks Meter: 106
Just short to capicitor near lcd conector{vio+vflash} n post result.Best luck.
Old 11-15-2010, 13:32   #3 (permalink)
Member: 891893
Thanks Meter: 24
Arrow
sorry bro not success
Old 11-15-2010, 14:16   #4 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 354
Never try to short any capacitor cause mostly capacitors have one side _ve & other side +ve supply everybody knows what will happened if we short _ve/+ve supply..............
Old 11-15-2010, 14:21   #5 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
boss very helpful lines u have written here the must have knowledge for the beginners..........
sanjubhai.
Old 11-15-2010, 14:22   #6 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
change the lcd connector from the board and then post results......
wbr: sanjubhai.
Old 11-16-2010, 05:45   #7 (permalink)
Member: 1291352
Thanks Meter: 106
why u short +ve _ve ? I mean just make a jumper batwen 2 power suply vio to vflash.
The Following User Says Thank You to Minded For This Useful Post:
Old 11-16-2010, 05:46   #8 (permalink)
Member: 1291352
Thanks Meter: 106
sanjubhai.
he dont understand me.Read my post again carefuly.
Old 11-16-2010, 05:54   #9 (permalink)
Member: 1291352
Thanks Meter: 106
plz try to understand me.I dont have a picture to atach so sory. A display connector have 10 pin.Left side up pin is no 1 and right side up pin is no 6 and right side last down pin is no 10.So 1st remove two capisiter near connector if not work just make a jumper batween pin no 6 and 7. If not work thean make a jumper again batween pin no 5 and 7. Ur provlem solved 100%i e u do this care fully.Try n post result. Best luck regard Shiva.
Old 11-16-2010, 05:57   #10 (permalink)
Member: 540345
Thanks Meter: 175
tri this.........
The Following 2 Users Say Thank You to asifawan For This Useful Post:
Old 11-16-2010, 06:31   #11 (permalink)
Member: 1284856
you are solution is vio and v cod lain to disply conecter chek
Old 11-16-2010, 10:55   #12 (permalink)
Member: 735102
Thanks Meter: 7
what is the password
Old 11-16-2010, 12:02   #13 (permalink)
Member: 1291352
Thanks Meter: 106
he forget password on his uncle home.
Old 06-19-2012, 16:48   #14 (permalink)
Member: 1103371
Thanks Meter: 19
Cool Nokia 1200 1208
Nokia 1200 1208 lcd jumper
Welcome to Cell Dial
Page generated in 0.23708 seconds with 10 queries
