06-10-2009, 13:04 | #1 (permalink) |
Crazy Poster Join Date: Jul 2007
Member: 542100 Status: Offline Sonork: http://cranktime.com/ Thanks Meter: 10 | nokia 1200 dead Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Error erasing area: 013C0000 - 013CFFFF i flashed it with jaff n here is the result Searching for default location of ini... Checking path: \Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: \Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.91if CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91if ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Changing flashing settings... Checking path: \Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.91ia CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91ia ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,Farsi,French,Urdu MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 Flash ID is 0x01000000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: d7 Loader is ready... P-key nokia module version 01.02 MSID: 84B419E39A602D535713B10BC0 MSID decoded: 3E4EBAE90013269AA8000000 FAID: 60652AD03BD51887C467005F Operation took 0 minutes 13 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 10 seconds... Writing... Permanent Data Restore FAILED! Operation took 11 minutes 56 seconds... Waiting for the last operation to finish... Restarting MCU... Failed! Aborting! can any 1 tell me where is the problem plzzzz hurry |
07-09-2009, 23:42 | #7 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Neo-SANA
Member: 292106 Status: Offline Sonork: 100.1582885 Thanks Meter: 116 | this will do First rehot cpu (UPP) try flash again..if same Rehot flash ic, problem will be solvedbr,thomp4pal Last edited by thomp4pal; 07-09-2009 at 23:52. |
Nokia 1200 Dead | ..::Rizwan::.. | Nokia Hardware & Hardware Repair | 9 | 08-10-2014 19:35 |
nokia 1200 dead in battey , in sw"insert sim card" | ameerali19 | Nokia Hardware & Hardware Repair | 4 | 01-26-2009 12:09 |
nokia 1200 dead | noman shakir | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-17-2009 09:47 |
nokia 1200 dead by flashing | jitugrover | HWK | 9 | 11-27-2008 15:38 |
