Old 10-14-2008, 15:11   #1 (permalink)
Member: 819976
Thanks Meter: 2
nokia 1200 ded halp meeeeeeeeee
1200 by jaf coneckte and chek mobail is on by test mode and not swichon halp meeeeeeeeeee
The Following User Says Thank You to narendra001 For This Useful Post:
Old 10-14-2008, 15:32   #2 (permalink)
Member: 267760
can u post the log...
Old 10-14-2008, 16:30   #3 (permalink)
Member: 819976
Thanks Meter: 2
Post 1200 ded halp meeeeeee
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.23
10-03-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: P06w45.v47
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.23
10-03-08
RH-99
(c) NMP
MG
ADSP SW version: V 5.23\n10-03-08\nRH-99\n(c) NMP\nmg
Production serial number: ING317866
Product code: 0546370
Module code: 0203402
Basic production code: 0564638
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354873026343758
IMEI spare to net: 3A 45 78 03 62 43 73 05
IMEI SV to net: 33 45 78 03 62 43 73 55 F4
Master Code: 6517332626
Phone type: RH-99, Software version: 5.23, Language Pack: MG
User code: ÿ#
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0546370
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Searching for default location of ini...
Checking path: \Products\RH-99\
Searching for JAF saved location of ini...
No ini files found...
Done!
softwyer ok and mob screen by test mode halp meeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 10-14-2008, 16:39   #4 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
me to bass please jaf team hlep me
Old 10-14-2008, 16:44   #5 (permalink)
Member: 819976
Thanks Meter: 2
[quote=narendra001;3745868]Getting MCU ID
MCU ID: 0x2292
Algo is ready...
Done!
Phone Restarted...
Reading...
10-03-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.23
10-03-08
RH-99
(c) NMP
MG
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
softwyer ok and mob screen by test mode and mob not on halp meeeeeeeeee
Old 10-14-2008, 17:33   #6 (permalink)
Crazy Poster
Member: 722092
Thanks Meter: 16
[quote=narendra001;3745898]
Originally Posted by narendra001 View Post
Getting MCU ID
MCU ID: 0x2292
Algo is ready...
Done!
Phone Restarted...
Reading...
10-03-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.23
10-03-08
RH-99
(c) NMP
MG
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
ERASE FLASH AND WRITE FLASH WITH GOOD PM 1ST
STILL SAME TRY THIS SOLUTION.POST RESULT........
GO TO THIS LINK......
http://forum.gsmhosting.com/vbb/show...=1200+TESTMODE
The Following User Says Thank You to SAMESHP For This Useful Post:
Old 10-15-2008, 13:57   #7 (permalink)
Member: 819976
Thanks Meter: 2
1200 no on
Getting MCU ID
MCU ID: 0x2292
Algo is ready...
Done!
Phone Restarted...
Reading...
10-03-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.23
10-03-08
RH-99
(c) NMP
MG
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
my mobail isjaf softwyre to coneckted to chak and mobail display with test mode but swich on but my mobail is not on and blank display halp meeeeeee
Old 10-15-2008, 14:15   #8 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
try this boss
Old 10-15-2008, 14:27   #9 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
http://img378.imageshack.us/my.php?i...n20off2qb6.jpg
Old 10-29-2008, 14:42   #10 (permalink)
Member: 663614
Cool Nokia 1200 test mode solution
REPLACE CHARGING CONNECTOR AND CLEAN THE AREA .FLASH WITH FULL FILE.PHONE WILL OK
Old 11-08-2008, 09:16   #11 (permalink)
Member: 819976
Thanks Meter: 2
Unhappy
Originally Posted by eswar7983 View Post
my bro no on charging and no on swich but jaf box replai is ok halp meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeee
Old 11-08-2008, 09:35   #12 (permalink)
jahednn's Avatar
Member: 790856
Thanks Meter: 532
Red face thanks sir
you problem is hardware 100%
Old 11-08-2008, 09:39   #13 (permalink)
ticksjarub's Avatar
Member: 534932
Thanks Meter: 49
youve been tyed dial 112, try replace lcd sir.
Old 11-13-2008, 13:51   #14 (permalink)
Member: 819976
Thanks Meter: 2
Unhappy
my 1200 jaf box conected and i clek to noramal mod and mobail on but i conecat to battery but no mobail on halp meeeeeeeeeeeeeeeeeeeeeeeee
Play mp3 ring tones in nokia 1200 khanmobiles0003 Nokia Base Band 5 ( BB-5 ) 1 01-31-2011 20:09
Play mp3 ring tones in nokia 1200,1208 khanmobiles0003 Nokia Digital Core Technology 4 ( DCT-4 ) 0 03-29-2010 18:50
NOKIA 1200 & 1208 SONGS FILES( PLAY MP3 TUNE IN NOKIA 1200 % 1208 ) mcu+ppm+cnt 100% majid55 Nokia Digital Core Technology 4 ( DCT-4 ) 4 06-08-2009 08:13
Need to convert nokia 1200 rh99 to nokia 1200 rh 100 krich70 Nokia Digital Core Technology 4 ( DCT-4 ) 0 05-23-2009 00:47
Page generated in 0.29344 seconds with 10 queries
