Old 04-08-2010, 16:38   #1 (permalink)
Member: 679928
Sonork: sadaf
Thanks Meter: 23
Wink nokia 1200 flash ok but ui setting fail
plz help any one i am watting
Old 04-08-2010, 16:39   #2 (permalink)
Member: 679928
Sonork: sadaf
Thanks Meter: 23
Old 04-08-2010, 16:53   #3 (permalink)
Member: 455842
Thanks Meter: 97
is test mode is on screen
Old 04-08-2010, 16:56   #4 (permalink)
Member: 455842
Thanks Meter: 97
if not download latest version
Deposit Files
Old 04-08-2010, 17:02   #5 (permalink)
mutunmobile's Avatar
Member: 570193
Thanks Meter: 31
frist chek cable then rehot cpu
Old 04-09-2010, 00:47   #6 (permalink)
Member: 326059
Thanks Meter: 5
u can do factory set manual and test 100%
Old 04-09-2010, 03:02   #7 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
post the log, will make us easier to analyze.
Old 04-09-2010, 04:01   #8 (permalink)
AlfskieCoder's Avatar
Member: 1225453
Thanks Meter: 501
Pull Out Resistor beside UEM...lyk in 6030
Old 04-09-2010, 04:06   #9 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
try clean a conector hf or charging n pin fbus from pcb
Old 04-09-2010, 04:08   #10 (permalink)
Member: 507861
Thanks Meter: 69
Old 04-09-2010, 04:28   #11 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
Post LoG................
i try Help u....
...:::SuraJ:::...
Old 04-09-2010, 05:43   #12 (permalink)
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,204
Flash with this vRH-105_dp_v_25_00..4.11.& post result.
nokia 5130 flashing ok but ui setting fail ravi mobile Nokia Base Band 5 ( BB-5 ) 2 10-29-2011 19:26
nokia 7210c flash ok but not need ui setting shaheb_anl Nokia Base Band 5 ( BB-5 ) 18 01-16-2010 14:57
6030 flashing complete but ui setting failed help me shivam4you Nokia Hardware & Hardware Repair 4 01-08-2009 06:21
Nokia 1200 flashing ok but not supported ID when patch imei Ramik Universalbox 7 07-10-2008 10:47
nokia 6600 software ok but ui settings failed please help mobilecitycbk Nokia Hardware & Hardware Repair 4 08-21-2007 09:13
Page generated in 0.16622 seconds with 9 queries
