Old 10-04-2008, 08:07   #1 (permalink)
Member: 301177
Thanks Meter: 91
nokia 1200 flashing error
i try to flash the phohe but it shows this massege every time i reball the flash but problem is still this is the log
1st Boot: Ok, DCT4, UPP: 2292 [Rh-99]
2nd Boot: u3_2nd.fia, Ver: 4.69.0
Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
Algorithm: u3_st_i.fia, Ver: 4.69.0
Algorithm Ok, MSID: 845B6ECE46C20A47F51AE893CB
Decoded MSID: 3E4EBAE9-005B3F55-A8000000
Encoded FAID: 5BFA44DC-1CE55AD1-40386AF1
IMAGE: rh99_04.110
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01
Area2: 0x01010000-0x013AFFFF Erased, Time: 01:06
Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:05
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:14
IMAGE: rh990_nai4.11mg
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:03
CNT Flashing Completed, Time: 00:01
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
need urgent help
The Following User Says Thank You to ameho0102 For This Useful Post:
Old 10-04-2008, 08:12   #2 (permalink)
Member: 229124
Thanks Meter: 20
full erase and flash again
Old 10-04-2008, 08:35   #3 (permalink)
laxman kumar's Avatar
Member: 733702
Sonork: 100.1579452
Thanks Meter: 579
IMAGE: rh99_04.110
need urgent help
this is hardware problem re try the re ball the flash ic than ty it
good luck bro
Old 10-04-2008, 08:44   #4 (permalink)
Member: 301177
Thanks Meter: 91
i try full erase the p hone and then flash but problem is still same log
IMAGE: rh99_04.110
Area2: 0x01010000-0x013AFFFF Erased, Time: 01:08
MCU Flashing Completed, Time: 00:15
what can i do
Old 10-04-2008, 08:58   #5 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
IMAGE: rh99_04.110
what can i do
try to flash it with jaf.........if same post log....
The Following User Says Thank You to digitized For This Useful Post:
Old 10-04-2008, 09:16   #6 (permalink)
Member: 838193
thanks sir for this......
Old 10-04-2008, 09:33   #7 (permalink)
Member: 301177
Thanks Meter: 91
MY I HAVE MT-BOX WHEN I TRY TO FLASH WITH MT-BOX ITS SHOWS THIS MASSEGE
ASIC ID: 2292
DCT4
u3_2nd.fia
u3_st_i.fia
845B6ECE46C20A47F51AE893CB36
Configuration Info (9F):
Number of Flashes: 2
01000000: SGS, 0020 8828 0000 0321, 10
02000000: NotUsed, 0000 0001 0000 0000, 0
ExtBUSC: AD3A 2208 010A 0A62 4908 09C4 410E 2514
Erase[4.31 MB]...
erasing region [01000000 to 0100FFFF]
erasing region [01010000 to 013AFFFF]
erasing region [013B0000 to 013EFFFF]
erasing region [017C0000 to 017EFFFF]
erasing region [01FC0000 to 01FEFFFF]
in 69.41s
Flash[2.25 MB]...in 11.92s
* * Processed file in 91.02 seconds
Processing File: rh990_nai4.11mg
Low level format...fail
Boot...
ASIC ID: 2292
DCT4
u3_2nd.fia
u3_st_i.fia
Erase[0.19 MB]...
erasing region [01380000 to 013AFFFF]
in 3.45s
Flash[0.15 MB]...in 0.83s
* * Processed file in 45.55 seconds
Extract content...fail
Processing File: rh99_04.11mg
Boot...
ASIC ID: 2292
DCT4
u3_2nd.fia
u3_st_i.fia
Erase[1.25 MB]...
erasing region [01240000 to 0124FFFF]
erasing region [01250000 to 0137FFFF]
in 21.61s
Flash[0.97 MB]...in 5.09s
* * Processed file in 35.78 seconds
* * * Phone flashing done in 3:57 minutes
Post Flash serial tunning of phone....
Pooling mode for full factory set...
Phone not responding, try to set manually!
Old 10-04-2008, 09:33   #8 (permalink)
Member: 301177
Thanks Meter: 91
What can i do for this problem i also reball the flash ic
Old 10-04-2008, 09:42   #9 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
sir you need to change the flash ic.....
Old 10-04-2008, 10:47   #10 (permalink)
Member: 301177
Thanks Meter: 91
if i change the flash ic i lost my imei then what can i do
Old 10-04-2008, 11:02   #11 (permalink)
Member: 873290
change the flash ic and cpu from a good phone
Old 10-04-2008, 16:11   #12 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
First reflow the flash chip. If not done reflow the CPU.
Post result.
Old 10-05-2008, 01:02   #13 (permalink)
multi_mobile's Avatar
Member: 502659
Thanks Meter: 97
1200 100% flash
some sets not 100%flash to jaff and ufs but universal box flash 100%
Old 10-05-2008, 19:43   #14 (permalink)
Member: 229124
Thanks Meter: 20
i flashed with UFS and easy cable !
Old 10-07-2008, 12:54   #15 (permalink)
Member: 301177
Thanks Meter: 91
at the day no sucess on this problem any body know the soluction pls provide me
1200 Flash Error Plz Help Me sonojee Nokia Hardware & Hardware Repair 2 07-29-2009 18:36
Nokia 1200 Flashing Problem here .::skybird::. Nokia Digital Core Technology 4 ( DCT-4 ) 3 07-03-2008 05:13
1200 Flashing Error Parminder Singh Nokia Hardware & Hardware Repair 8 06-16-2008 08:17
how to flash nokia 1200 flash with mt-box GHOST_GSM MT-BOX 5 12-11-2007 09:35
Nokia 1200 Flash not support az_liton MT-BOX 2 11-17-2007 06:51
Page generated in 0.44576 seconds with 8 queries
