Old 09-10-2008, 15:54   #1 (permalink)
.::MD_AKTER::.'s Avatar
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
Nokia 1200 power problem
Nokia 1200 power on with DC power suply at 4.1 voltage. But Power failed with battery. any 1 can give me properly solution ?
Thank.
The Following User Says Thank You to .::MD_AKTER::. For This Useful Post:
Old 09-10-2008, 16:20   #2 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
Originally Posted by akter_hosain View Post
nokia 1200 power on with dc power suply at 4.1 voltage. But power failed with battery. Any 1 can give me properly solution ?
Thank.
what is your mobile history.water or felldown.please post detail.........
Old 09-10-2008, 16:28   #3 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
are you flas it if yes log please.
Old 09-11-2008, 11:00   #4 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
Here is jaf log:-
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
Phone Type:
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.230
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.23ic
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh1050_nai5.23ic
MCU: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.230
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 843D7D9807B468A4FFDC4C496E
MSID decoded: 3E4EBAE900D53397AA000000
FAID: BE8F08A3542C733AF4E2B842
Operation took 0 minutes 11 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 1 minutes 9 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.23ic
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 848574C93C3042FEB24C52FA4C
MSID decoded: 3E4EBAE900D53397A8000000
FAID: FD8186511A5D42E72CBE702D
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 22 seconds...
Writing...
Operation took 0 minutes 7 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh1050_nai5.23ic
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84FCEB189F5963944B78170DBB
MSID decoded: 3E4EBAE900D53397A9000000
FAID: 008B7B2787648FD45D0F21A2
Operation took 0 minutes 10 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Operation took 0 minutes 1 seconds...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 35 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 5.23
IMEI: 356382023116819
Product Code: 0549920
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 5 seconds...
Done!
Done!
Setting local mode...
Reading imei...
IMEI/ESN: 356382023116819
Reseting warranty data...
Reseting LifeTimer...
Lifetime data not found!!!
Done!
Old 09-11-2008, 11:36   #5 (permalink)
Member: 724680
Thanks Meter: 928
normal mode failed or ok,change rebon and lcd then flas.
Old 09-11-2008, 11:55   #6 (permalink)
Member: 798645
Nokia 1200,1208 no power on with battry
Thank.
my brother battry conector (-) to make jumer near point battry conector your problem 100% solved
Old 09-11-2008, 12:53   #7 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
Please give me a jpg to [email protected]
Old 09-11-2008, 13:02   #8 (permalink)
Member: 659586
Thanks Meter: 86
try with this solution..
salam.
The Following 4 Users Say Thank You to arnold marpaung For This Useful Post:
Old 09-11-2008, 20:28   #9 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
salam.
Thank for reply, But this step has complate, Same probleme.
Old 09-11-2008, 20:53   #10 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
bra....check on /off buton there 2 vol or not if less vol then u need jumper or rehot uem ic
Old 09-11-2008, 22:13   #11 (permalink)
Member: 675717
Thanks Meter: 125
Yes this power key possitive problem if power key track is ok rehot or reball UEM.
Old 09-12-2008, 08:46   #12 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
Normal mode ok.
But power don't on battery.
Old 09-12-2008, 09:04   #13 (permalink)
Member: 198738
Thanks Meter: 5
your problem Same problem with local mode,try again
nokia 1200 power on/of ways khanmobiles0003 Nokia Hardware & Hardware Repair 7 07-21-2011 12:21
nokia 1200 power way. nangia khan Nokia Hardware & Hardware Repair 1 03-22-2010 07:55
nokia 1200 power way. nangia khan Nokia Hardware & Hardware Repair 1 03-22-2010 07:49
1200 power problem kenecee Nokia Hardware & Hardware Repair 3 12-16-2009 08:29
Page generated in 0.23124 seconds with 10 queries
