Old 11-05-2009, 13:31   #1 (permalink)
Member: 1122148
Thanks Meter: 35
nokia 1202 is not swiching on
i have nokia 1202 it was faildown then it was not swiching on then try to cheh shorting was ok after i connect with HWK try to falsh phone booting n giving info but i couldnt see the local on screen then flash with same SW 3.10 process was ok but ohone is not swiching on
n
more then check screen but its looks like ok
any solution pls
Thank u
Old 11-05-2009, 13:36   #2 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,685
just check BSI track.....
Old 11-05-2009, 14:01   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,161
n
any solution pls
Thank u
Bro.try it.
if not ok
reaplace uem ic.
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 11-05-2009, 14:13   #4 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
remove its bsi resistor ur problem will be sllove
Old 07-08-2010, 13:58   #5 (permalink)
Member: 1331655
Sonork: umar
dear i have nokia n95 cell but within working lcd is blank i replace it but same condition do u have solution then tell me i m very thankful to u.
nokia 1202 is dead shakil143 Nokia Hardware & Hardware Repair 10 10-08-2010 12:16
nokia 3500c Flash is ok with HWk nut not swiching on shakil143 Nokia Hardware & Hardware Repair 8 10-30-2009 12:07
Nokia 6100 is not switched on witux Nokia Hardware & Hardware Repair 1 10-20-2005 18:35
Nokia 5110 not swich ON ! Ved Nokia Hardware & Hardware Repair 1 05-12-2002 23:09
Page generated in 0.31656 seconds with 8 queries
