Nokia 1208 Hang Problem..... Dear Expert... I am facing problem nokia 1208 hang and restart. When i power on it's work fine for some time like one or two minutes. after that it's doing problem hang or some time direst restart without hang some hang and restart. I already try to full erase and then full flash but problem not solve.. then i decide to open phone and try to change upp.. after change upp with working phone but not solved. "fualted phone upp work fine other phone" . So after read many post i decide to change keypad Ic then SIM Is and then change sound IC ..... but problem still there in phone .... after deep testing through Oscilloscope i find fualt on flash IC , So i change with working phone flash IC. after that i am so confused because problem show again.. "after chang flash IC phone was work perfect for 5 minutes." after testing and thing one day . I decide to change UEM , so i change this one ... Now problem is same........ Plz Plz plz help me i am so confused. Waiting perfece reply... Ps. plz note i already chang PA for testing but not solved.:confused::confused::confused: |
change both flash ic & uem from working phone otherwise replace new uem and write rpl because here is a imei issue |
I already change from working phone UEM and Flash IC... plz note i already change UEM new one but problem same... waiting... |
this hanging in 1208 is a serious problem please anyone with absolute solution |
u need to full erase and flash wit latest flash file and write pm and also do patch 100% problem solved |
1208 is water dameg................ |
i have nokia 1110 , 1200, 1208, 1209, 1650 all are the handsets are dead ... when i trying to flash these phones with jaf Getting MCU ID MCU ID: 0x2201 FLASH ID0: 84039406 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 04010400 <=> Flash ID not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 77 40 45 A5 B4 44 B4 45 F7 66 E7 A1 57 82 15 63 Checking RAM for ALGO... Can't find flash loader for this phone...Aborting! please tell me the exact solution for this problem........ i am waiting for your reply.. lots of thanks in advance |
Flash ic problem try to reboll or replace |
I have solve this problem to day by change the UPP, or you may try to reball first if its failed than change UPP, 100% solved!!!!! *** Luck...bro! |
just re hoot cpu only 10000000000000000%%%%%%%%%%%%%%%%%%%%% okkkkkkkkkkkkkk man |
for hang and rerstart first reball upp if same change cpu its tested |
first change display strip, after change to check display i have solved this problem many time |
brother i got the same then i changed RTC now it is working |
change to cpu and erase flash then write software with pm and complete ui setting 100000000% ok tested by me |
