Old 08-22-2008, 19:58   #1 (permalink)
Member: 785753
Thanks Meter: 57
Nokia 1208 hang & restart
After resoldring dead nokia 1208 it starts slowly and restart after 1 minute
pls some body help me
The Following 5 Users Say Thank You to vvsory For This Useful Post:
Old 08-22-2008, 21:28   #2 (permalink)
err
Member: 288302
Thanks Meter: 3
try to full flashing
thanks,
The Following User Says Thank You to err For This Useful Post:
Old 09-27-2008, 16:11   #3 (permalink)
Member: 774443
Sonork: 100.1603978
Thanks Meter: 40
Nokia 1208 restart problem plice help me
Old 09-27-2008, 16:28   #4 (permalink)
morshad1's Avatar
Member: 274362
Thanks Meter: 25
1st full erase then flasg
Old 09-27-2008, 17:48   #5 (permalink)
Member: 618439
Thanks Meter: 9
hay sir i try it but not working plezz help another soultion thanks
Old 09-27-2008, 17:50   #6 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
1Full Flash.
Reboll cpu
The Following User Says Thank You to shivashakthi For This Useful Post:
Old 10-01-2008, 15:18   #7 (permalink)
SHARMA NEERAJ's Avatar
Member: 419331
Thanks Meter: 94
chack crystel than just heat cpu last reboll cpu
The Following User Says Thank You to SHARMA NEERAJ For This Useful Post:
Old 10-01-2008, 16:15   #8 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,510
flash with jaf first full erase and flash secand ok pm and unlock
The Following User Says Thank You to ..::ohm::.. For This Useful Post:
Old 10-01-2008, 16:21   #9 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
first try with latest firmware if still same try to change clock crytal or 26mhz crystal......
The Following User Says Thank You to digitized For This Useful Post:
Old 10-01-2008, 18:02   #10 (permalink)
.::VijayAnand::.'s Avatar
Member: 740523
Thanks Meter: 93
first reboll cpu then u flash the mobile
The Following User Says Thank You to .::VijayAnand::. For This Useful Post:
Old 10-01-2008, 18:54   #11 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
1200 restart
Its not a perfect solution. And this fault is come highly rate
The Following User Says Thank You to sameer918 For This Useful Post:
Old 10-01-2008, 21:01   #12 (permalink)
Member: 785753
Thanks Meter: 57
i tried every methode but dint got any solution of my problem i think its imposible to solve still same thing ......i got 3 1200 and 1 1208 but didnt repaired any set.....
The Following User Says Thank You to vvsory For This Useful Post:
Old 10-02-2008, 16:06   #13 (permalink)
morshad1's Avatar
Member: 274362
Thanks Meter: 25
maybe this is hardware problem
The Following User Says Thank You to morshad1 For This Useful Post:
Old 10-02-2008, 18:13   #14 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
yes is hardware problem please change cristal 26mhz
The Following User Says Thank You to xEDIx For This Useful Post:
Old 10-02-2008, 18:16   #15 (permalink)
amardeepsahi's Avatar
Member: 357914
Thanks Meter: 71
erase and flash and write good pm if not solve then it is a cpu problem reball it ur problem must solve
The Following User Says Thank You to amardeepsahi For This Useful Post:
nokia n70 hang & restart alammov Nokia Hardware & Hardware Repair 6 03-25-2010 17:12
Nokia 2300 Hanging & restart Problem Ankit Verma Nokia Digital Core Technology 4 ( DCT-4 ) 3 10-25-2008 10:20
Nokia 6680 Hangs & Restarts valentine aquil Nokia Hardware & Hardware Repair 7 08-02-2008 12:57
Nokia 1110i Hang & Restart Ankit Verma Nokia Hardware & Hardware Repair 2 05-31-2008 07:03
Nokia 6680 Hang & Restart zakir375 Nokia Hardware & Hardware Repair 10 12-13-2007 16:50
Page generated in 0.44373 seconds with 8 queries
