nokia 1208 rh 105 contact service pro hi to all brother s i i have nokia 1208 rh 105 its contect service i check with mx key and ufs on normal mode it s show contact service i sp unlock with mx key and ufs but problem same plz help me his solution |
today i also got a phone 1650,c.s ,i unlock it with mx-key,write full pm nd flash but it is still contact services. Phone Type: RM-305 SW Version: V 5.53 07-08-08 RM-305 (c) NMP Imei plain: 35321003393954-5 Product Code: 0557977 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Language Pack: - not available. Imei net: 35321003393954 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN here is self test Phone Type: RM-305 SW version: V 5.53 07-08-08 RM-305 (c) NMP ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y !failed ! 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N !failed ! 52 KASUMI N passed plz,help anyone. me also. |
ues jaf full erase flash and unlock pm wirte 100 okkkkkkkkkkkkkkkkkkkkkk nokia 1208 and nokia 1650 |
good solution pro......................... |
According to self test report it seems that the problem is of SIM IC Better to change sim ic and than check WBR Jyoti |
Bro,i changed sim ic after that my phone was ok and self test was ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N !failed ! 52 KASUMI N passed but after few miunute again phone is showing contact services and again self test result is- ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y !failed ! 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N !failed ! 52 KASUMI N passed NOW,PLZ ANYONE TELL ME WHERE IS FAULT. |
1st full erase & flash with update version like 5.71 etc |
write good pm . |
but not solved. and strange case is that when i m giving small heat on cpu than it is working well but when it goes cool than again contact services |
his solution i have nokia 1208 rh 105 its contect service eras 1208 rh 105 after flash new varjan after unlock and pm writ with p key and jaf his solution ok ur set |
flash than write good pm thane unlock with mcu thane full factory your problem solve.Post result.:) |
1 full flash with jaf 2 write pm 3 unlock your problum 100000000000% ok |
