08-15-2007, 09:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | Nokia 6030 Charging Problame Pls I Have Problem Abut Provlame Nokia 6030 Charging Problame. When I Canected Mobile With Charger Then Not Showing Anything In Monitor. Pls Send Me Solve. Thanks, Babu |
The Following 2 Users Say Thank You to DIGITAL BABU For This Useful Post: |
08-15-2007, 11:27 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | If 'not Charging' Is Indicated On The Display, I Could Be Talking Of The Charging Block Glass Ic, But Now Since Nothing Is Shown On The Display, You Need To Ascertain The Functionality Of The Charger. If The Charger Is Okay, Check The Dc Jack Port Where The Charger Plug Is Inserted For Presence Of Charge Voltage. Do This By Cheking With Multimeter Tester With Range Switch Set At 20 Volts And Then Apply The Two Leads Of The Meter On The Two Pins Of The Charging Port. Perhaps The Phone Is Suffering From A Damaged Port. Good Luck. |
Nokia 1110-1600-6030 charging solution | r a nadeem | Nokia Hardware & Hardware Repair | 70 | 09-07-2012 15:18 |
nokia 6030 restart problam pleas halp me. | azizby02 | Nokia Hardware & Hardware Repair | 1 | 11-07-2009 18:15 |
nokia 6030 restart problam pleas halp me. | azizby02 | Nokia Hardware & Hardware Repair | 0 | 11-07-2009 18:06 |
nokia 6030 light problame | sachin_udai | Nokia Hardware & Hardware Repair | 1 | 10-26-2008 17:25 |
Not Charging Nokia 6030 | Lucky Assad | Nokia Hardware & Hardware Repair | 3 | 09-03-2008 14:44 |
