10-04-2015, 16:01 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Mind
Member: 2147085 Status: Offline Thanks Meter: 53 | Please study these diagrams very carefully before you start repairing. Nokia 1208 charging problem solved 100%. this image is to solve not charging problem in nokia 1208. check the parts given in diagram re hot resold or replace if not working after resold. see also some related post given bellow. Nokia 1208 not charging solution ways path. Nokia 1208 Charging Problem Not Charging Charging Ways Charging Solution Not Charging Solution Charge Tracks Nokia 1208 charging problem solved 100% Nokia 1208 not charging solution ways path. this image is shown which components are used in charging function in nokia 1208. check the links with mull ti meter if any link is broken make jumper as shown in diagram source |
The Following User Says Thank You to iCore For This Useful Post: |
