nokia 1280 not power on when i put the battery nokia 1280 when i connect the atf box bus check or scan phone ..phone is power on . but i put the battery or power on phone phone is not power on ......plz suggest me ??????????????????? |
1280 no power on battery brother try another battery or check battrey conectoer |
Brother I Think Your Battery Connector Middle Point is Mitch math Problem. http://www.u2ugsm.com/blog/wp-conten...m-Solution.jpg Regard Brother Palash Ahammad |
all point track is ok |
ya i too faceing this problem plz can any gsm friend provide any solution |
is that any solution for this |
post ufs info log here. mosly lcd problam change lcd. |
bro charjing ok plzz other soltioin |
no solution . . . . .still warring somebody help me |
re-hot power ic (uem) your problem will be solved 100000% |
if the set shows charging but no power on then there must be power ways missing. check the power switch way |
remove bsi rasistor & short it |
1280 Power Switch Ways http://forum.gsmhosting.com/vbb/atta...6&d=1331964271 |
