Old 11-21-2009, 12:00   #1 (permalink)
Member: 258092
Thanks Meter: 11
nokia 1600 auto off when idle
i have no clue how to fix this phone
the phone power off itself when the light go off
Old 11-21-2009, 13:34   #2 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
first change a *** battery if not open your set clean with ctc give some heat
best of luck
Old 11-21-2009, 13:41   #3 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,686
1ST check imei... 2ND reflash ur set if not work then rehot UPP
Old 11-21-2009, 15:28   #4 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,539
1 Set is of due to poor battery
2 some points (bubbles) are disconnect under the CPU
solution
1 change battery connector
2 change battery
3 give heat cpu carefully
this is 100% tested i repair many mobile set with this method
The Following User Says Thank You to gul551 For This Useful Post:
Old 11-21-2009, 15:29   #5 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,539
press thanks button for me
The Following 2 Users Say Thank You to gul551 For This Useful Post:
Nokia 1600 Auto power off reaj Nokia Hardware & Hardware Repair 10 01-30-2013 03:49
nokia 5530 auto off when making call vertex777 Nokia Base Band 5 ( BB-5 ) 13 03-01-2012 11:05
I have a Nokia 6600 which auto off when i make any call tanveershaheen Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-10-2007 09:01
A35 Auto OFF when Lamp OFF Hary Siemens Hardware Repair Area 4 12-19-2002 20:10
Nokia 3310 Auto Off When Signal Low Williamcwy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-20-2002 03:08
Page generated in 0.28302 seconds with 8 queries
