Old 07-11-2009, 16:11   #1 (permalink)
.::skybird::.'s Avatar
Member: 594884
Thanks Meter: 1,553
Nokia 1600 battery low and shut down!!!
Problem is :
Using with battery (signals down battery low and shut down)
.................Using with power supply 04.0 to 04.5V (signals down battery low and shut down)
.................Using with power supply 05.0V working fine.
Have anybody any solution for this?
.::skybird::.
Old 07-11-2009, 16:17   #2 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 734
br try it..............
The Following 2 Users Say Thank You to biniesh_08 For This Useful Post:
Old 07-11-2009, 16:24   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,219
Originally Posted by .::skybird::. View Post
Problem is : Using with battery (signals down battery low and shut down)
.::skybird::.
Bro.try it........
The Following 3 Users Say Thank You to mahbubalfa For This Useful Post:
Old 07-11-2009, 16:27   #4 (permalink)
Member: 594884
Thanks Meter: 1,553
I've been already used this solution but not solved and also removed 3 resistances near the battery connector.
The Following User Says Thank You to .::skybird::. For This Useful Post:
Old 07-11-2009, 19:39   #5 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
brother change pa 100% ok
post reply
Old 07-12-2009, 16:04   #6 (permalink)
Member: 594884
Thanks Meter: 1,553
It also have no signal problem with ZONG and UFONE sim!!!!!
The Following 2 Users Say Thank You to .::skybird::. For This Useful Post:
Old 07-12-2009, 16:15   #7 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,540
i think brother its PA problem,,,,i also agree with chamak_-liton
try that and post result
Old 07-12-2009, 16:27   #8 (permalink)
Member: 594884
Thanks Meter: 1,553
It's right that pa can solve this problem (low network, battery low shut down) but are you sure that it can also make network fine with ZONG and UFONE sim? I also tried solution see post #3. and erase flash, write flash latest version, write good pm, unlock, factory set.
Old 07-13-2009, 04:51   #9 (permalink)
Member: 594884
Thanks Meter: 1,553
NOW PA CHANGED BUT SAME PROBLEM..........
pls share your experience to solve this problem
Old 07-13-2009, 05:12   #10 (permalink)
Member: 1054255
Sonork: BISMILLAH.M.S.CENTER
Thanks Meter: 92
Arrow 1208
100% SALUTION IS POST BY ashad420...I TEST IT FEW PHONE.THANKS.
The Following User Says Thank You to romajess For This Useful Post:
Old 07-13-2009, 06:02   #11 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,540
last solution is power ic,,,,,,,,,,,,,,,,,i think like that,,,,,,,
Old 07-13-2009, 09:17   #12 (permalink)
Member: 594884
Thanks Meter: 1,553
3 pa changed and problem is still there.................
Old 07-16-2009, 14:47   #13 (permalink)
Member: 594884
Thanks Meter: 1,553
i have been also maked pa short jumper now signals comes and then down!!!
Old 07-17-2009, 20:31   #14 (permalink)
Member: 735673
Thanks Meter: 3,101
new solution is power ic probelem
NOKIA 1110/1112/1600 Battery low SolutionNOKIA 1110/1112/1600 Battery low Solution gsm junction Nokia Hardware & Hardware Repair 3 05-06-2013 13:02
Sigmatel s90 low bettery shut down avi4uni Chinese Models & Cloned Phones 6 02-25-2010 10:48
NOKIA 1110/1112/1600 Battery low Solution rubel_chk007 Nokia Hardware & Hardware Repair 2 08-17-2009 11:01
ztc tv800 low batry shut down shsampath Chinese Models & Cloned Phones 1 05-02-2009 08:12
B2050 After Battery Low & Shut Down DYNET LG 2 09-30-2008 08:55
Page generated in 0.41160 seconds with 8 queries
