Old 06-24-2008, 17:54   #1 (permalink)
shok9992000@yah's Avatar
Member: 578941
Thanks Meter: 108
nokia 1600 dead
nokia 1600 dead & ufs says this
1st Boot: Ok, DCT4, UPP: 2201 [Rh-64]
2nd Boot: u_2nd.fia, Ver: 4.69.0
Fl0: 0x01000000-0x01FFFFFF,F7D3F7D3, UNKNOWN CHIP !
FLASH DEVICE NOT SUPPORTED
Check Product, Use newer Flash Update Pack
Algorithm: u_intel.fia, Ver: 4.69.0
Rebooting Mobile
What to do is it flash ic defect
Old 06-24-2008, 17:58   #2 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,514
Yup its a flash ic problem simply heat up the flash ic then flash the phone ypur problem is solved.
Thankz.
Xtreme Mobile.
BRB.
The Following User Says Thank You to Vijendra Saini For This Useful Post:
Old 06-24-2008, 18:15   #3 (permalink)
Member: 578941
Thanks Meter: 108
i tried to heat flash ic but of no use
The Following User Says Thank You to [email protected] For This Useful Post:
Old 06-24-2008, 18:19   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 890
If u have JAF then just CHK ur phone and u will know all what is the problem
The Following User Says Thank You to alamgarh For This Useful Post:
Old 06-24-2008, 18:43   #5 (permalink)
Member: 578941
Thanks Meter: 108
JAF Says
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: F3F3F3F3 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: F3 F3 F3 F3 F3 F3 F3 F3 F3 F7 F3 F7 F3 F7 F3 F7
Checking RAM for ALGO...
Can't find flash loader for this phone...Aborting!
Old 06-24-2008, 18:47   #6 (permalink)
Member: 774126
Sonork: 100.1645006
Thanks Meter: 42
then flash ic is dead, if its not glued, change it
Old 06-24-2008, 18:57   #7 (permalink)
Member: 578941
Thanks Meter: 108
sorry but its glued .so i think i can't do anything now, am i right
Old 06-25-2008, 07:56   #8 (permalink)
Member: 278058
Thanks Meter: 81
UPP can cause this also
Old 06-25-2008, 08:35   #9 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
brthr first reball cpu ... ur problem will solve tested ........
Old 06-25-2008, 11:04   #10 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 146
re:
" bro i do agree with both the suspect is upp too in this case besides flash ic, thanx"
The Following User Says Thank You to mobilespeed For This Useful Post:
Old 06-25-2008, 11:18   #11 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,347
nokia 1600 Dead & Ufs Says This
1st Boot: Ok, Dct4, Upp: 2201 [rh-64]
2nd Boot: U_2nd.fia, Ver: 4.69.0
Fl0: 0x01000000-0x01ffffff,f7d3f7d3, Unknown Chip !
Flash Device Not Supported
Check Product, Use Newer Flash Update Pack
Algorithm: U_intel.fia, Ver: 4.69.0
Rebooting Mobile
What To Do Is It Flash Ic Defect
water Damaged?give Me About This.......
Old 06-28-2008, 13:16   #12 (permalink)
Member: 774126
Sonork: 100.1645006
Thanks Meter: 42
JAF Says
Getting MCU ID
MCU ID: 0x2201
flash loader is situated in flash ic, and if the flashing device can not find the flash loader, then it can't flash hence flash ic dead, replacing upp won't help.
The Following User Says Thank You to cavi For This Useful Post:
nokia 1600 dead after flash by J.A.F Plez help voice-cracker Nokia Digital Core Technology 4 ( DCT-4 ) 6 07-16-2009 16:06
nokia 1600 dead paklink UFS2 + UFS3-Tornadoflasher 7 11-28-2007 03:31
My nokia 1600 dead with mt-box peter24533 MT-BOX 1 07-02-2007 19:05
Nokia 1600 Dead By Twister sDinesh Twisterflasher 3 08-08-2006 22:25
Page generated in 0.37747 seconds with 8 queries
