Old 08-13-2012, 22:54   #1 (permalink)
Arzzu's Avatar
Member: 1611261
Sonork: 1677675
Thanks Meter: 62
Question Nokia 1600 display & keypad light Automatic
Nokia 1600 display & keypad light Automatic on
Pls help
The Following User Says Thank You to Arzzu For This Useful Post:
Old 08-14-2012, 05:29   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change 3 leg transister
post result
Old 08-14-2012, 05:53   #3 (permalink)
Member: 1722829
Thanks Meter: 3
try to clean. it might the board is shorted
Old 08-14-2012, 18:48   #4 (permalink)
Arzzu's Avatar
Member: 1611261
Sonork: 1677675
Thanks Meter: 62
Sir I have Already Change 3 leg transister
Also Clean Pcb Properly..........
Result Same
Need Help.........
Old 08-14-2012, 20:43   #5 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Change Light IC if not solved then change UEM
Old 08-15-2012, 08:34   #6 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
Originally Posted by Arzzu View Post
Sir I have Already Change 3 leg transistor
Result Same
Need Help.........
took another same board and check 3 leg transistor is shorted.
if you unable to do this just remove light ic and make a good light jumper.
as usual just use search button to find the solution
Old 08-15-2012, 11:22   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
u mean when u insert battery light on
please add more detail so its easy to help
Old 08-15-2012, 11:31   #8 (permalink)
Member: 1614117
Thanks Meter: 34
1.fist remove remove capacitors from light section & 3leg timer.
2.replace it from another board,make sure 3leg tips not shorted,
3.if same problem:then replace light ic,
if any problem.call me @ 9331331333
Page generated in 0.18573 seconds with 9 queries
