Old 12-06-2011, 17:53   #1 (permalink)
Member: 1174964
Thanks Meter: 6
nokia 1600 display light problem.
i get a nokia 1600, which display light is not working..its complete light section(ic,coil,cap, light,resist, trans) parts are lost..can any solution for display light without any parts on displya backlight section......
Plzz sugest me some easy method to fix it...
Thanks in advanced..
Old 12-06-2011, 18:09   #2 (permalink)
Member: 1174964
Thanks Meter: 6
thanks for reply...but unable to see pic...plz repost ur solution...
Old 12-06-2011, 18:21   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,209
post ur pcb light section here
so its easy to help u
Old 12-06-2011, 18:27   #4 (permalink)
Member: 458253
Thanks Meter: 29
1600 light solution
http://www.ziddu.com/download/177106...PERT20JUMP.JPG
Old 12-06-2011, 18:49   #5 (permalink)
Member: 1514183
Thanks Meter: 33
1110 luz probado.JPG - 4shared.com - photo sharing - download image
Old 12-07-2011, 09:17   #6 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 152
i am uploading images it may help you as image no 002 i have done so many times always it works, the other thing is remove lcd light (led) form lcd, trace the ground of lcd it is no-3 one side of the led make ground other one from keypad light +ve side or you can trace track from lcd connector pin no 7 it is also goes in lcd
Old 12-07-2011, 09:56   #7 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 152
some more easy way to understand
Old 12-07-2011, 09:59   #8 (permalink)
alexcolt45's Avatar
Member: 1466588
Sonork: 109875676
Thanks Meter: 45
try this bro.....
Old 12-07-2011, 10:01   #9 (permalink)
Member: 1174964
Thanks Meter: 6
thanks lovepreet ...i will try...thanks alot...
Old 12-07-2011, 10:07   #10 (permalink)
helpful-man's Avatar
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,508
here your solution 100% tested
Aplay this jumper
Old 12-07-2011, 11:05   #11 (permalink)
Member: 1174964
Thanks Meter: 6
but my coil tracks are damaged...how i can jumper for coil...
Old 12-07-2011, 12:37   #12 (permalink)
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,508
no need any parts
this solution only work new local Lcd
The Following 4 Users Say Thank You to helpful-man For This Useful Post:
Old 12-07-2011, 18:13   #13 (permalink)
Member: 1174964
Thanks Meter: 6
Originally Posted by helpful-man View Post
no need any parts
Just worked in 1110 black n white display.....
Any trick for working in 1600 color display...
Anyway thanks for ur good solution...
The Following User Says Thank You to GETACTIVE For This Useful Post:
Old 12-08-2011, 05:05   #14 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,234
it is work on nokia 1110/1600/2310 phone.tested
Old 12-08-2011, 05:48   #15 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 152
1110 and 1600 are same pcd thear is no different the light section is if it is working on 1110 it must work on 1600 (just try local lcd ) specialy lcd had one led inside
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.42973 seconds with 9 queries
