Old 01-11-2014, 03:18   #1 (permalink)
birruvijay's Avatar
Member: 1197753
Thanks Meter: 32
Nokia 1616-2 flashing ok but not power battery
Nokia 1616-2 full flashing normal mode display on but insert battery not power on bsi line ok please solution
Old 01-11-2014, 04:32   #2 (permalink)
Member: 2047354
Thanks Meter: 9
check on-off ways or check ground pin in battery connector to connected pcb ground or change also display. if still problem not solve then rehoot powaer ic.
Old 01-13-2014, 09:12   #3 (permalink)
samithashiva's Avatar
Member: 1356665
Sonork: 123
Thanks Meter: 31
Originally Posted by birruvijay View Post
nokia 1616-2 full flashing normal mode display on but insert battery not power on bsi line ok please solution
try to ceck display track and display
Old 01-16-2014, 23:18   #4 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
This does not have to do with display ways or track. Power ways need be checked for continuity in this case.
Old 01-16-2014, 23:24   #5 (permalink)
Member: 684493
Thanks Meter: 24
Short bsi and ground then check it ll be on ........
Old 01-17-2014, 08:31   #6 (permalink)
Member: 1584831
Thanks Meter: 46
chek voltage in on off switch
Old 07-15-2015, 12:29   #7 (permalink)
Crazy Poster
Member: 1780708
Sonork: 62645
Thanks Meter: 7
hands set on tested bye me
Page generated in 0.15325 seconds with 8 queries
