04-20-2008, 07:53 | #17 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 568843 Status: Offline Thanks Meter: 47 | network problem depends on the condition of the mobile 1.fell down ,in this case u have to rework the uem ic 2.water lodged, in this case the problem is some other like insert simcard keys not working or no ring tone if we fix that problem the next problem automatically generates is network problem ,so we have to do is rework the uem ic because when heat the board to remove the ic it will damage the uem ic .so rework will solve the problem use good hot air ****er constant temp we can remove the glued ic easily heat the ic 3-5 minutes be care full i am using AOYUE 852 keeping temp 340 air full want very good experience in removing glued ic .this is what attended the problem in 1110 1600 &so....i did 7 board like this |
The Following 3 Users Say Thank You to campus For This Useful Post: |
04-20-2008, 08:10 | #18 (permalink) |
Member: 568843 Status: Offline Thanks Meter: 47 | is any body experienced above mention the case i will tell u how to remove simcard ic & keypad ic without using hot air ****er.try this, use soldering stick of 25w keep the heated stick on top of the ic, put more lead to the stick wait until the ic comes out, then make jumpers so we can solve this by using only soldering stick .so other problem will not generate ......................have a good day....... enjoy |
08-27-2008, 18:48 | #19 (permalink) |
Freak Poster Join Date: Dec 2007 Location: INDORE (INDIA) Age: 36
Member: 661499 Status: Offline Thanks Meter: 76 | 1600 no ring no speaker ringer ic print lost -------------------------------------------------------------------------------- help me i have 1600 i want ringer ic jumper |
The Following User Says Thank You to jain gourav For This Useful Post: |
08-27-2008, 18:59 | #20 (permalink) |
Member: 661499 Status: Offline Thanks Meter: 76 | 1600 network problemhttp://forum./show...3+1110+network |
08-29-2008, 18:35 | #21 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | when 1600 maximum time i will solved my problem change 2 filters if not done change rf......and i get scusses if not done then only try to jumper |
08-29-2008, 19:57 | #23 (permalink) |
Freak Poster Join Date: Jun 2007 Location: East Jurain, dhaka, Bangladesh Age: 44
Member: 535623 Status: Offline Sonork: 100.1586332 Thanks Meter: 21 | please anybody say 100% work.................................. i will try all soloution but not work..... thanks.. |
04-25-2009, 17:06 | #29 (permalink) |
Junior Member Join Date: Apr 2009 Location: Kolkata,WB, India
Member: 1017479 Status: Offline Thanks Meter: 0 | I Hv A Nokia 1200 Handset With A Problem In Network, I hv Already Heated And Flashed But There Is No Network Identifying Signals, I hv Also Tried Network Selection Search In Manual Mode But The Result Was "no Network Coverage Found n handset gets restarted" Please Help Me In This Regard. Thank U |
1600 no ring tone & no incoming voice | abhishekh53 | Nokia Hardware & Hardware Repair | 26 | 08-15-2011 16:25 |
1600 no mic, no ringer, no speaker | alamgarh | Nokia Hardware & Hardware Repair | 15 | 03-02-2009 00:22 |
1600 no ring no speaker ringer ic print lost | shani72 | Nokia Hardware & Hardware Repair | 7 | 08-14-2008 12:47 |
1600 no ringing tone but works speaker and mic no vibrator | oranz | Nokia Hardware & Hardware Repair | 5 | 01-27-2008 16:51 |
SONY ERIC T100 " no network" | ali25 | Sony Ericsson Hardware Repair | 7 | 12-08-2004 21:35 |
