Nokia 1600:not Charging :confused: pLEAse I need solution for nokia 1600 not chaging .Please with diagram. |
cheack battery connector |
http:///vbb/search.php use this.......... |
solutin first check your battery than battery conector than your set beloy rite site means fuse site there three parts are near each other and check 22 no resistance. irfanpasha regards! |
chakc if your battery is not dead, or check if the charging connect or check the battery connector |
1600 nokianotchargingjumpering |
1 Attachment(s) Quote:
old solution pls some new solution |
nokia all not charging/ charger not supported 1:- change and check charger 2:- change and check battery 3:- check bsi contact and usb socket funges 4:- remoove and check BSI track thermister 5:- replace Btemp themister 6:- remove and check BSI track resister ( this resister connected to power IC) any hand sets dead after remove this resister -then replase the resister 7:- change and check PM file 8:- refit or replace Power IC or Charging IC 9:- re fit the CPU please following the steps in service [email protected]:confused: |
