09-15-2006, 16:14 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Africa
Member: 180758 Status: Offline Thanks Meter: 13 | Nokia 1600:not Charging |
The Following 2 Users Say Thank You to The Razor For This Useful Post: |
09-15-2006, 20:53 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
http:///vbb/search.php use this.......... | |
The Following 2 Users Say Thank You to c_ahmad79 For This Useful Post: |
09-15-2006, 21:29 | #4 (permalink) |
Insane Poster Join Date: Mar 2006
Member: 248040 Status: Offline Thanks Meter: 10 | solutin first check your battery than battery conector than your set beloy rite site means fuse site there three parts are near each other and check 22 no resistance. irfanpasha regards! |
The Following User Says Thank You to irfanpasha For This Useful Post: |
08-22-2011, 07:31 | #14 (permalink) |
Junior Member Join Date: Feb 2007 Location: kottakkal
Member: 458017 Status: Offline Thanks Meter: 7 | nokia all not charging/ charger not supported 1:- change and check charger 2:- change and check battery 3:- check bsi contact and usb socket funges 4:- remoove and check BSI track thermister 5:- replace Btemp themister 6:- remove and check BSI track resister ( this resister connected to power IC) any hand sets dead after remove this resister -then replase the resister 7:- change and check PM file 8:- refit or replace Power IC or Charging IC 9:- re fit the CPU please following the steps in service [email protected] |
nokia 3110c charging show but not charging | umesh garg | Nokia Hardware & Hardware Repair | 28 | 02-25-2012 12:48 |
nokia 3310 charges but not storing charge | nellabe | Nokia Hardware & Hardware Repair | 3 | 05-24-2010 19:20 |
lg kg 270 charging solotion with nokia 6300 charging jeck Guljee | guljee786 | LG Hardware Repair | 0 | 03-02-2009 08:04 |
lg kg 270 charging solotion with nokia 6300 charging jeck Guljee | guljee786 | LG Hardware Repair | 11 | 03-02-2009 07:08 |
All Nokia Not Charging,sine End Charging Problem Here | gsm st | Nokia Hardware & Hardware Repair | 5 | 11-20-2007 08:40 |
