Old 11-29-2007, 01:47   #1 (permalink)
Member: 265244
Thanks Meter: 3
nokia 1600 urgent
got this nokia 1600 from a friend he say that he just wake up and see on the phone insert sim ,,he took out the sim and replace it but its jus the same ,,try different sim in it same thing ,, what might cause this ,,no water or anything like that got into it so i dont know ,,anyway he said someone told him that the circuit board is dead ,,could that be so ???? it still shows demo of evrything on the phone just not reading no sim ,,whats the fix if any????
Old 11-29-2007, 08:58   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
SIM IC ..( Crystal or glass)
Old 11-29-2007, 17:32   #3 (permalink)
Member: 265244
Thanks Meter: 3
not sure !!!!where is that located ,, and if crystal what i do ,,,if glass what i do ..thanks
Old 11-30-2007, 10:25   #4 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
first of all chek this .....
http:///vbb/attach...7&d=1179733102
The Following User Says Thank You to .::BHATTI::. For This Useful Post:
Old 11-30-2007, 10:26   #5 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
if not works .. then try changing this IC ...
http:///vbb/attach...7&d=1179724861
Old 11-30-2007, 14:49   #6 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
it is sim ic falt just change it all will b ok
Old 11-30-2007, 15:56   #7 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
its sim ic fault , just replace it
problem solve
if you have no sim ic then you can jumping to the sim ic
use search button for the jumping
Old 11-30-2007, 16:06   #8 (permalink)
shahidsattar's Avatar
Member: 388454
Thanks Meter: 1,101
1110 sim fault
most of the time charing and handsfree area is water damaged clean it wit ctc . then change or shortn the sim ic.
Old 11-30-2007, 16:23   #9 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Some times maybe it is battry problem.
If the battry fitting is not properly then result is this...........................................
Post result.
Old 11-30-2007, 22:16   #10 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Change sim ic near sim tray of the mother board.
Old 11-30-2007, 22:38   #11 (permalink)
Member: 470292
Thanks Meter: 147
First of all
1. check that the middle battery point connects to the middle terminal.
2. Sim card connector points.
3. Resold Simcard ic near simcard connector. ( upper crystal)
4. Change Simcard ic. or make jumpers. click the link
The Following User Says Thank You to adnanskyland For This Useful Post:
Old 12-01-2007, 10:18   #12 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
dear see this pic and remove SIM Ic make jumper
File Type: jpg 1600_1110_6030 INSERT SIM CARD FULL WAY 1.JPG (191.6 KB, 186 views)
Old 04-01-2008, 19:42   #13 (permalink)
Member: 542743
Thanks Meter: 81
One 1600 INSERT SIM CARD PROBLEM.
L2001 AND C2013 WERE OXYDISED.
CLEANED WITH IPA.
C2013 FOUND TOTALLY DAMAGED.
REMOVED IT.
CHARGER CONNECTOR REPLACED.
STILL THERE IS THE PROBLEM.
ANYBODY HAS ANY SOLUTION?? PLZ HELP
IS THERE ANY POSSIBILITY OF THE PROBLEM DUE TO C2013??
Old 04-02-2008, 20:39   #14 (permalink)
Member: 408586
first checkout when power on the handset how insert sim show (instantly or after 2or 3 seconds)
if instantly then its from sim ic,simjack,simtrack and
if shows after 2,3 seconds then check the battery connector's middle pin(it bend or not or not touching the battery),missing supply of middle pin and
atlast check the battery.
i m 1000% sure about this fault.
Old 06-05-2008, 16:57   #15 (permalink)
ashok_kumar459's Avatar
Member: 202500
Thanks Meter: 234
1110 insert sim need solution.....
if uem demage sim tray 3 and 6 is shot. then unable to repair
nokia 1600 urgent solution please yuvrajkuber HWK 2 02-18-2010 09:32
nokia 1600 urgent soultion please yuvrajkuber MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-18-2010 09:10
please, i need erase file for nokia 1600 urgent ! mg70brz Griffin 5 12-27-2009 06:39
Nokia 1600 help urgent without_soul666 HWK 3 06-03-2007 17:52
Page generated in 0.27311 seconds with 11 queries
