Old 05-10-2009, 02:39   #1 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
Nokia 1600b Contact Service-5
hello
I get Nokia 1600b Made in MAXICO. when power it on without sim card, it works fine.
But I put the Sim Card, it says Contact Service-5.
First time m facing this problem.
I faced many contact service in Nokia 1600. but its strange. in 1600 usually Contact service appear in the in Blue LCD and in this Blue Light have written Small Contact Service.
But in this fon. Contact service-5 shows just like when we power on the phone without sim card and phone says Insert Sim Card in Large Words.
here is the log took from J.A.F.
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.00
10-24-06
RH-65
(c) NMP
HW version: 0529
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: SDI:LD184v89
PPM version: V 6.00
10-24-06
RH-65
(c) NMP
UB
ADSP SW version: V 6.00\n10-24-06\nRH-65\n(c) NMP\nub_lta
Production serial number: RCR059171
Product code: 0532765
Module code: 0202592
Basic production code: 0536232
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 010783000552280
IMEI spare to net: 0A 01 87 03 00 55 22 08
IMEI SV to net: 03 01 87 03 00 55 22 38 F1
Master Code: 2043205074
Phone type: RH-65, Software version: 6.00, Language Pack: UB
User code: #
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-65.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0532765
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-65\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-65\
Searching for JAF saved location of ini...
No ini files found...
Done!
If any friend have any idea about it plz share as soon as possible.
Thanx in Advance.
Old 05-10-2009, 02:48   #2 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
try to replace new lcd mate
i encounter that problem only from lcd
if nothing to solved via software...write pm
Old 05-10-2009, 08:03   #3 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
ok let me try. Thanx 4 reply
Old 05-10-2009, 08:07   #4 (permalink)
Member: 1010481
Searching for JAF box ...
JAF box detected
Box firmware version: 1B1
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-322
Version: V_04.61_15-10-07_RM-322_(c)_Nokia
IMEI: 358983010780661
SP LOCK status:
Config Key: 8000000000000006
Provider Key: 2343300000000000
Block 1: CLOSED Type 5 Data: 23433F
Block 2: CLOSED Type 5 Data: 23486F
Counters: 0/3, 0/10
Phone is Locked
Read Phone Info OK
Type: RM-322
SP LOCK status:
Counters: 0/3, 0/10
Phone is Locked
Reading PM Field 308 Subfield 1 with length 8192 bytes
PM308 readed OK
BB5 FLASH bb5challenge ...
ASIC ID: 000000010000022600010006010C192101001101
HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
CMT Boot Ready
HELLO
start
JAF BB5Plus No TP by [c]Cinek started.
ok
Initial PM 308 sent
Certificates sent
Unlocked PM 308 SL buffer received
Unlocked PM 308 field build OK
After unlock.
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Type: RM-322
SP LOCK status:
Config Key: 8000000000000000
Provider Key: 0010100000000000
Block 1: OPEN Type 5 Data: 00101F
Counters: 0/3, 0/10
Phone is Unlocked
Read Phone Info OK
Successfully done.
Old 05-10-2009, 08:09   #5 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 881
unlock it
br shashank
Old 05-10-2009, 08:20   #6 (permalink)
amit_deswal22's Avatar
Member: 778346
Thanks Meter: 30
unlock it
yesterday i have done 1600b as u told flash with jaf and tick on factory set,
manual flash,unlock then select ini rh-64 1600
then all will be ok.
Old 05-10-2009, 08:39   #7 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
I have changed its LCD but still giving problem.
Actually b4 doing and Software or Hardware I want to confirm that what is the exact fault in it.
if any friend have faced this problem plz share with me.
Old 05-10-2009, 08:43   #8 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
Originally Posted by shashankmobile View Post
unlock it
br shashank
I have unlock it but still on Contact Service-5
any other idea?
Thanax u guys for reply.
Old 05-10-2009, 13:40   #9 (permalink)
Member: 778346
Thanks Meter: 30
flash + unlock
As u told bro i got same set with same problem yesterday.
In jaf tick on unlock button and flashed with rh-64 1600 file
100% tested i got rid of this problem.
still u r getting problem meet me in yahoo messenger
[email protected]
Old 05-10-2009, 13:45   #10 (permalink)
Member: 800668
Sonork: 100.1590720
Thanks Meter: 881
erase it full and flash it with 1600b
write pm and unlock
br shashank
Old 05-10-2009, 13:58   #11 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 539
You should have readed HERE.
Your phone originaly came from Tracfone USA in that thread is your solution post #4....
Old 05-10-2009, 16:17   #12 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
My Problem solved by Erase it and flash it then write PM and unlock.
Now phone is working well.
Thanx for u all friends to reply and helping me.
Old 05-10-2009, 16:36   #13 (permalink)
inamullah's Avatar
Member: 407178
Thanks Meter: 22
1 FULL ERASE
2 FULL FLASH WITH LATEST FILES
3 WRITE PM
4 UNLOCK
5 RESTORE FACTORY SETTINGS
6 eNJOY
Old 06-30-2009, 23:42   #14 (permalink)
Member: 179402
Thanks Meter: 21
can you attach the Pm please
Old 09-07-2009, 16:12   #15 (permalink)
Member: 432364
Thanks Meter: 268
I did write 1600 pm file and changed both filters but still network is not showing....Can u plz share your 1600 pm so i will try with that...Thx...
B.r.
Nokia 1600B - Contact service 5 pls. help... Joda Nokia Hardware & Hardware Repair 1 08-29-2009 18:59
Nokia 1600b Contact Service-5 faisal4friend J.A.F. Plus 1 06-01-2009 11:50
nokia 1600b contact service 5 lacasapc J.A.F. By Jafsupport.com 2 06-02-2008 13:20
Page generated in 0.43674 seconds with 8 queries
