Old 01-07-2014, 18:02   #1 (permalink)
Member: 1976478
Thanks Meter: 3
nokia 1616-2
Hi ..
I have this phone.Man told me thatwas spoiled water on the phone.
I conected to power suply.When i press the power button the ampere needle goes just a liitle bit a movement and then goes back again.The same thing when i press the power button.
The ampere needle does a very very small movement just about 0,01(two zeros) when i press the power button
Old 01-07-2014, 22:36   #2 (permalink)
KorAll's Avatar
Member: 1702061
Sonork: 100.1651562
Thanks Meter: 306
Originally Posted by kon.electronics View Post
Hi ..
What you must to do:
1. Clean phone PCB and dry it.
2. Do full selftest with box (UFS, Best, ATF)
3. Place result here.
_________________________________________________
Logic is the iron made.
need help?Than press "Thank button" There is no counter for given thanks.
Old 01-09-2014, 19:28   #3 (permalink)
Member: 1976478
Thanks Meter: 3
today i got Iso propyl,I did a good clean with toothbrush and i give heat to its three ICS on the motherboard.
These phone has only three IC.
DADAAAA and the Phone TURNED ON.
The other thing that matters me now.its the screen
More than halfed screen is black and other is white.i dont get any signal from phone.Half WHITE and MORE than HALF (BROKEN-BLACK-CRACKED).
So do you beleive that change the screen will solve the problem or do i have to change SCREEN IC also?
Old 01-09-2014, 21:50   #4 (permalink)
KorAll's Avatar
Member: 1702061
Sonork: 100.1651562
Thanks Meter: 306
2. Do full selftest with box (UFS, Best, ATF) and Phoenix - best service soft for Nokia phone. You may test lcd with Phoenix.
I try to help you for this comical salary -
Old 01-10-2014, 00:19   #5 (permalink)
Member: 1976478
Thanks Meter: 3
since i dont have the box isnt any here who sell as used?iam gonna need it for my work in future
Page generated in 0.15942 seconds with 8 queries
