nokia 1616 dead any body help me . nokia 1616 dead. when i flash that phone flashing ok but not power on. i allready change lcd. any help from this fourm members |
sir i have 1616 water damage set i clean it and when i flash, after flash phone turn on but not on with battery........ what is the solution pls help me Thanks in advance |
sir i solve my problem with a jumper now my phone was working good....... i don't know how to upload image to this forum if anyone want the solution call me on 9052660333 i will mail you that image anyway thank you so much for your replys thankssssssssssss |
way ok but set not work............... |
mobile pc normal mode on but battery connection set not on..... |
hi pliz help me get the unlock code for nokia 161 and the IMEI no is 359042049835431, thanx |
Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RH-125_95FE3350A701EAEE_IMEI.back) MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085A94B Using device: HTI, FW ver: 00.50, SN: 00013E27 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Processing file: rh125_003.610 Downloading item CODE:hw_f11_rh125_r03.610.fls, num block: 3, size: 4.04 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 38.953 s Erasing area 0x00C60000-0x00E5A5FE ...OK Programming completed in 36.828 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.125 s Checksum verified (0x9BE4) Processing file: rh125_003.61aa Downloading item CUST:hw_f11_rh125_003.61aa.fls, num block: 1, size: 2.13 MB Erasing area 0x00210000-0x0042F4BE ...OK Programming completed in 39.156 s Checksum verified (0x1F90) Processing file: rh1250_nai03.61aa Downloading item CUST:hw_f11_rh1250_nai03.61aa.fls, num block: 1, size: 330.89 KB Erasing area 0x00EB0000-0x00F01E7E ...OK Programming completed in 6.078 s Checksum verified (0x8F3C) Total time for flashing process(boot+erase+write) was 2 min 47.125 s Phone type: RH-125 SW version: V 03.61 29-01-10 RH-125 (c) Nokia Imei plain: 35270404862349-1 Product code: 0595840 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei net: 35270404862349 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.5 Server: No such product code: 0583104 Server: No such product code: 0583104 Destination path: C:\Program Files\Nokia\Phoenix\Products\RH-125\ RH125_0583104_03.61_001.vpl already exist, download skipped. RH125_0583104_03.61_001.dcp already exist, download skipped. rh1250_nai03.61aa already exist, download skipped. rh125_003.61aa already exist, download skipped. rh125_003.610 already exist, download skipped. 0583104_SimLockDataVerifier_vDCT4.sim already exist, download skipped. RH125_0583104_03.61_001.spr already exist, download skipped. RH125_0583104_03.61_001_signature.bin already exist, download skipped. Download completed. Handset not work ??????????????/ plz help |
Brother chk the lcd ways if all point are ok then change lcd |
