Old 12-18-2010, 16:45   #1 (permalink)
anajnisha's Avatar
Member: 1033632
Thanks Meter: 60
nokia 1616 dead
any body help me . nokia 1616 dead. when i flash that phone flashing ok but not power on. i allready change lcd. any help from this fourm members
Old 06-11-2011, 14:19   #2 (permalink)
Member: 1360730
Thanks Meter: 5
sir i have 1616 water damage set i clean it and when i flash, after flash phone turn on but not on with battery........ what is the solution pls help me
Thanks in advance
The Following 2 Users Say Thank You to shareef_786 For This Useful Post:
Old 06-11-2011, 14:28   #3 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,032
kindly try to on with box if your phone is on with box then your phone is ok not change lcd if your phone still possession then change lcd or repair hardware aria
The Following User Says Thank You to rafi_5217705 For This Useful Post:
Old 06-11-2011, 14:34   #4 (permalink)
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,032
Thanks in advance
you must on phone with software box if your phone on with box Then pres power button if your phone is of then repair battery terminal way
Old 06-12-2011, 04:43   #5 (permalink)
Member: 1360730
Thanks Meter: 5
sir i solve my problem with a jumper now my phone was working good.......
i don't know how to upload image to this forum if anyone want the solution call me on 9052660333 i will mail you that image anyway thank you so much for your replys thankssssssssssss
Old 06-12-2011, 05:03   #6 (permalink)
***MALIK***'s Avatar
Member: 556396
Sonork: 100.1609417
Thanks Meter: 340
here is jumper solution
The Following User Says Thank You to ***MALIK*** For This Useful Post:
Old 09-03-2012, 11:47   #7 (permalink)
Member: 1461196
Sonork: taposhbd
Thanks Meter: 20
way ok but set not work...............
Old 09-03-2012, 11:56   #8 (permalink)
Member: 1461196
Sonork: taposhbd
Thanks Meter: 20
mobile pc normal mode on but battery connection set not on.....
Old 09-03-2012, 12:44   #9 (permalink)
Crazy Poster
Member: 1805242
Sonork: moon
hi pliz help me get the unlock code for nokia 161 and the IMEI no is 359042049835431, thanx
The Following User Says Thank You to moonluck For This Useful Post:
Old 11-05-2012, 14:00   #10 (permalink)
Member: 1106037
Sonork: raman
Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RH-125_95FE3350A701EAEE_IMEI.back)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085A94B
Using device: HTI, FW ver: 00.50, SN: 00013E27
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rh125_003.610
Downloading item CODE:hw_f11_rh125_r03.610.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 38.953 s
Erasing area 0x00C60000-0x00E5A5FE ...OK
Programming completed in 36.828 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.125 s
Checksum verified (0x9BE4)
Processing file: rh125_003.61aa
Downloading item CUST:hw_f11_rh125_003.61aa.fls, num block: 1, size: 2.13 MB
Erasing area 0x00210000-0x0042F4BE ...OK
Programming completed in 39.156 s
Checksum verified (0x1F90)
Processing file: rh1250_nai03.61aa
Downloading item CUST:hw_f11_rh1250_nai03.61aa.fls, num block: 1, size: 330.89 KB
Erasing area 0x00EB0000-0x00F01E7E ...OK
Programming completed in 6.078 s
Checksum verified (0x8F3C)
Total time for flashing process(boot+erase+write) was 2 min 47.125 s
Phone type: RH-125
SW version: V 03.61 29-01-10 RH-125 (c) Nokia
Imei plain: 35270404862349-1
Product code: 0595840
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: AA
Language Pack:
English,Dannish,Norwegian,Swedish
Imei net: 35270404862349
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.5
Server: No such product code: 0583104
Destination path: C:\Program Files\Nokia\Phoenix\Products\RH-125\
RH125_0583104_03.61_001.vpl already exist, download skipped.
RH125_0583104_03.61_001.dcp already exist, download skipped.
rh1250_nai03.61aa already exist, download skipped.
rh125_003.61aa already exist, download skipped.
rh125_003.610 already exist, download skipped.
0583104_SimLockDataVerifier_vDCT4.sim already exist, download skipped.
RH125_0583104_03.61_001.spr already exist, download skipped.
RH125_0583104_03.61_001_signature.bin already exist, download skipped.
Download completed.
Handset not work ??????????????/ plz help
Old 11-05-2012, 14:20   #11 (permalink)
zoiya's Avatar
Member: 740220
Sonork: 100.1654997
Thanks Meter: 213
Brother chk the lcd ways if all point are ok then change lcd
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.38870 seconds with 8 queries
