Old 05-01-2011, 07:04   #1 (permalink)
Member: 1545731
Sonork: n/a
Thanks Meter: 26
nokia 1616 flash ok not power on
nokia 1616 flash ok with mxkey not power on plz help me
Old 05-01-2011, 07:44   #2 (permalink)
chipset experts's Avatar
Member: 1312914
Thanks Meter: 111
change lcd ...........
The Following User Says Thank You to chipset experts For This Useful Post:
Old 05-01-2011, 07:47   #3 (permalink)
SANWER's Avatar
Member: 581945
Sonork: 100.1601426
Thanks Meter: 51
change lcd ...........100% tested.
Old 05-01-2011, 08:00   #4 (permalink)
Member: 1566725
Thanks Meter: 3
change lcd if not ok then check for lcd ways
B.R
gsm-helper
Old 05-01-2011, 08:04   #5 (permalink)
Member: 1422587
Sonork: 100.1600692
Thanks Meter: 14
CHINGS LCD
Old 05-01-2011, 08:10   #6 (permalink)
Member: 1126839
Thanks Meter: 22
Check LCD line if ok just change LCD your problem solve
Old 05-01-2011, 08:11   #7 (permalink)
md_amin's Avatar
Member: 1217931
Sonork: 100.1604251
Thanks Meter: 135
Sem problem my u or phone.....Nokia 1616
flash ok mxkey AND full Info......
Old 05-01-2011, 08:11   #8 (permalink)
biswajit74's Avatar
Member: 900306
Thanks Meter: 36
before change lcd check info ............
Old 05-08-2011, 10:14   #9 (permalink)
Member: 1545731
Sonork: n/a
Thanks Meter: 26
lcd change is not power on amper plz 2.3 plz help me
Old 05-08-2011, 18:19   #10 (permalink)
jaijee's Avatar
Member: 450110
Thanks Meter: 183
Flash with ATF.......
and
Post result...
Because atf tell lcd test faild...
Old 05-08-2011, 19:08   #11 (permalink)
Member: 277937
Thanks Meter: 48
brother 1616 ,1800. c1.1280 cant flash if u know its realy 100% software problem otherwise problem create to solve these set.
and i have solution but here i know not how can i paste
Old 05-08-2011, 20:01   #12 (permalink)
Mind Power's Avatar
Member: 338106
Thanks Meter: 55
check if it is giving info if it gives info than check is it poweron on supply if it it ons on power supply than clean parts behind bater connector also check bsi ways and also clean chargeing jack if no solved than check lcd
Old 05-09-2011, 08:19   #13 (permalink)
Member: 1551281
Sonork: kathiresan
Thanks Meter: 7
1616 boot ok no power
brother try atf 100 % solve u r problem
Old 05-09-2011, 08:26   #14 (permalink)
Ramuwalia's Avatar
Member: 1298426
Sonork: 100.1603765
Thanks Meter: 233
no need to change lcd just put off lcd and fix it again ur problam will b solved tested meny times
Old 05-09-2011, 08:37   #15 (permalink)
Member: 326059
Thanks Meter: 5
be sure to battery connector spicealy bsi and re sold it
Page generated in 0.34539 seconds with 8 queries
