03-20-2011, 14:09 | #1 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | Nokia 1616 help Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...RX Buffer: 01AB |
03-20-2011, 14:46 | #5 (permalink) |
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | From BEST team for Infinity users FREE BB5 Easy Service Tool - card found: S/N 7A74:0116 Port COM1 open OK Connect phone on selected interface... Wait... Connections timeout... Port COM1 close Port COM1 open OK Connect phone on selected interface... Wait... Connections timeout... Port COM1 close Port COM3 open OK Connect phone on selected interface... Wait... Connections timeout... Port COM3 close Port COM1 open OK Connect phone on selected interface... Wait... Connections timeout... Port COM1 close |
03-21-2011, 06:11 | #7 (permalink) |
03-21-2011, 06:37 | #8 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
dead or? | |
03-21-2011, 08:25 | #11 (permalink) |
Freak Poster Join Date: May 2008 Location: Philippines
Member: 783116 Status: Offline Thanks Meter: 52 | Check cable and its connection to pinout Sometime I've encounter that when i buscheck 1616 in mx-key But it's DONE when I connected the cable properly Br |
03-22-2011, 02:55 | #12 (permalink) |
Junior Member Join Date: Dec 2006 Location: łódź
Member: 404370 Status: Offline Thanks Meter: 18 | Backup saved to C:\mobileEx\3.4\data\backup\XGOLD_RH-125_177936963F220D91_IMEI.back Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK BLS (EPOCH,DATE,KEYFIX): SE0_091125 F11 Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing file: rh125_004.650 Downloading item CODE:hw_f11_rh125_r04.650.fls size: 4.08 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 31.891 s Erasing area 0x00C60000-0x00E6407E ...OK Programming completed in 31.172 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.109 s Checksum verified (0x1FF2) Processing file: rh125_004.65ea Downloading item CUST:hw_f11_rh125_004.65ea.fls size: 1.77 MB Erasing area 0x00210000-0x003D4F3E ...OK Programming completed in 27.343 s Checksum verified (0x711E) Processing file: rh1250_nai04.65ea Downloading item CUST:hw_f11_rh1250_nai04.65ea.fls size: 321.77 KB Erasing area 0x00EB0000-0x00EFF9FE ...OK Programming completed in 4.922 s Checksum verified (0x39F1) Total time for flashing process(boot+erase+write) was 2 min 15.031 s Phone Type: RH-125 SW Version: V 04.65 24-04-10 RH-125 (c) Nokia Imei plain: 35197704389253-2 Product Code: 0587396 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EA Language Pack: - not available. Imei net: 35197704389253 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN use mykey, its ok i have tis same problem but mxkey help my |
03-24-2011, 14:04 | #14 (permalink) |
Member: 404370 Status: Offline Thanks Meter: 18 | Backup already exists(C:\mobileEx\3.4\data\backup\XGOLD_RH-125_9166D0C29CEC54A7_IMEI.back) Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK BLS (EPOCH,DATE,KEYFIX): SE0_091125 F11 Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing file: rh125_006.200 Downloading item CODE:hw_f11_rh125_r06.200.fls size: 4.10 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 32.328 s Erasing area 0x00C60000-0x00E6983E ...OK Programming completed in 31.891 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.109 s Error reading checksum! ---why?? Processing file: rh125_006.20ea Downloading item CUST:hw_f11_rh125_006.20ea.fls size: 1.77 MB Erasing area 0x00210000-0x003D51BE ...OK Programming completed in 23.719 s Checksum verified (0xAA03) Processing file: rh1250_nai06.20ea Downloading item CUST:hw_f11_rh1250_nai06.20ea.fls size: 324.64 KB Erasing area 0x00EB0000-0x00F0057E ...OK Programming completed in 5.046 s Checksum verified (0x1F58) Total time for flashing process(boot+erase+write) was 3 min 6.078 s Phone Type: RH-125 SW Version: V 06.20 01-12-10 RH-125 (c) Nokia Imei plain: 35622904602451-4 Product Code: 0598087 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EA Language Pack: - not available. Imei net: 35622904602451 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
03-24-2011, 14:31 | #15 (permalink) |
Member: 404370 Status: Offline Thanks Meter: 18 | Backup already exists(C:\mobileEx\3.4\data\backup\XGOLD_RH-125_D8F148E77F181FA9_IMEI.back) Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...Boot acknowledge code is invalid (0x0.2x) ! phone flash only when uncheck safe flash & fast flash |
