Old 09-06-2012, 06:47   #1 (permalink)
Member: 1665634
Thanks Meter: 7
Arrow nokia 1616 only on with power supply not with battery
i have nokia 1616, it only on with power supply but when i use original battery its not on.
my phone is normal, i was change battery, check connector battery its normal.
any solution.
Old 09-06-2012, 06:52   #2 (permalink)
Member: 619199
Thanks Meter: 47
there is not perfect solution for this problem check components right side of batttery connector....
Old 09-07-2012, 12:41   #3 (permalink)
Member: 852547
Sonork: 100.1621506
Thanks Meter: 40
check bsi track, it will b alive
Old 09-29-2014, 09:10   #4 (permalink)
Member: 1574998
Thanks Meter: 10
I also suffering same problem. Any solution bro?
Old 09-30-2014, 04:46   #5 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 42
bro just change 2 parts near battery connector hope your problem solved..only thanx
Old 09-30-2014, 05:06   #6 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
any solution.
no need to change any part just check bsi line damage
your problem solve 100%
Old 09-30-2014, 06:04   #7 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
atach gnd to bsi line phone on in bettry
Old 10-02-2014, 13:08   #8 (permalink)
Member: 1924279
Thanks Meter: 14
Old 10-02-2014, 13:09   #9 (permalink)
Member: 1924279
Thanks Meter: 14
[IMG]http://www.google.co.in/imgres?*****l=http://www.u2ugsm.com/blog/wp-content/uploads/2011/02/1616-on-off-switch.jpg&imgrefurl=http://www.u2ugsm.com/blog/power-on-off-switch-key-line-paths-for-nokia-1616/&h=548&w=813&tbnid=BVkr4Vlv9_iBLM:&zoom=1&q=1616%2 0on%20off%20ways&docid=2nTlW4TMc6jJSM&ei=GEAtVJ7IM 5SfuQS6sICYDA&tbm=isch&ved=0CBwQMygAMAA&iact=rc&ua ct=3&dur=1302&page=1&start=0&ndsp=18[/IMG]
Page generated in 0.20353 seconds with 9 queries
